Ball Joint time.
Old Jan 11, 2012 | 07:45 AM
  #31
locknload223's Avatar
locknload223
Originally Posted by Snowseeker
Always make sure the jackstand is solidly on the axle. I always used to put the jackstand on the tube itself and bumped up against the spring pack so it couldn't slide. Also leave the jack under the axle next to the jack stand, it may be in the way a little bit but double the safety is a good thing! Many of man have had their legs cut off by falling cars or worse. Also important to use wheel chocks when using jack stands.
You're right. I actually left the jack under the axle but brought it in the garage when I went on my socket hunt, I just didn't put it back right away. I did and always do shake the living hell out of the truck before I start work, just to make sure the stand and truck are set.
I used a Smart Car as a wheel chock.
Old Jan 11, 2012 | 07:50 PM
  #32
njneer1's Avatar
njneer1
Good choice on the Smart Car wheel chock Mike......I use them myself now.....with that pointy nose they work much better than the Mini Coopers I was using.
Is that a poly seal on the Napa premiums ? what did they run you ?......I think I jinxed myself.....or you did....I swear my RF wheel is leaning a bit....and I have started hearing a slight knock under the front.....gonna check the BJ this weekend.
Old Jan 12, 2012 | 04:27 AM
  #33
locknload223
Yeah they're poly. The ball joints look a lot nicer than most, gold cad plating and a polished stem (didn't want to say shaft, oops... just did) plus they're suppose to have beefier guts, to be purely scientific. Some boxes said Made in Taiwan but the guy brought one out that said Assembled in USA so I had him find another USA to match. I know all that means is assembled from foreign parts but hey, every little bit of USA helps.
They were a little more than the Moog from Advance Auto. The Napa premiums were, $84 for the lower and $54 for the upper. That's fine though, I don't mind spending a little more on ball joints.
That sucks if yours went out. How old are they? You said TRW right? What's the warranty? Did you grease up that large seal enough to re-use it if need be?
Old Jan 12, 2012 | 08:36 PM
  #34
njneer1's Avatar
njneer1
Mine are 5yrs and 70k miles old......not sure they are bad yet.....just hearing a clunk.....will check this weekend.....the warranty is lifetime....but I won't use them again if they are shot....but I will get the replacements for the shelf.....never know when I will need them. Yes should not have a problemgreased the new seals well last time.
spongecop
21
Sep 13, 2016 02:36 PM
rougerocco
Sep 16, 2014 10:23 AM
Ford4dog
1997 - 2003 F150
Oct 28, 2008 10:03 PM
kinchaser
Dec 19, 2007 09:33 PM
Kenworth
Jul 14, 2007 05:00 PM
