Sponsored by: Real Truck
Repeated Ball Joint Replacement
Old Oct 2, 2007 | 10:43 AM
kinchaser's Avatar
kinchaser
HELP!
04 F250 6.0L Crew Cab. Today she's getting the THIRD set of 4 ball joints in 13 months. This 2nd set is 5 months old.
No one seems to have a clue as to what is causing these multiple failures.
I have more mechanical understanding then I do knowledge (I'm female, please don't count that against me) but SOMETHING must be putting excessive wear/tear/pressure/cattywhompus on the joints (like the technical speak?)
Truck has only 51K, gets only a few miles a week on gravel otherwise all paved roads, regular service, and the only accident was when a dealer's driver backed a wrecker into it, putting a 'nice' ding in the hood when it was 4 months old. Hood replaced, no other damage.
THANKS!
Old Oct 2, 2007 | 11:35 AM
rwilimo's Avatar
rwilimo
What Brand of joints are you using and what kind of failure are you experiencing?
Old Oct 3, 2007 | 01:12 AM
DavidE200016936's Avatar
DavidE200016936
I made the mistake of having NAPA ones installed and they lasted 50,000 (orig went 179,000) Have ford back in and now at 300,000 doing fine.
Old Oct 3, 2007 | 07:16 AM
dkf's Avatar
dkf
IMO the current ball joints on these heavy SDs are too small. If it were me up to me they would be bigger and beefier.
The PSD diesel is alot heavier than the gassers which adds more strain on the ball joints. However several sets of ball joints in a little over a year should never happen.
I've heard guys have them replaced at 25k miles, which should not have to be either.
All ball joints should have grease fittings. The rollers get dry and gritty eventually and start to go south.
Old Oct 3, 2007 | 07:48 AM
kinchaser's Avatar
kinchaser
Ball Joints
These are all Ford Factory, dealer installed ball joints.
I can't be much more specific on the type of failure beyond the fact inspection shows they're shot. This time I was told they're 'loose'. In May I brought it in for grinding noise when turning the wheel at slow speed (3 point turn, etc.) Sounded to me like the steering wheel pump (ex had a 70s model F150) but they found them toast again. That set had been installed the previous August.
Old Oct 3, 2007 | 12:58 PM
DavidE200016936
I had a dealer tell me that mine would not make the next state inspection (PA). One month later while rotating the tires I found that the axle bearing was bad, not the ball joint. It also made a bad grinding noise when turn at slow speeds. Soon it made alot of noise at all speeds (lol). But it got me home and I replaced it myself. Check to see about the bearings, cause 2 different techs said it was a ball joint. GOOD LUCK!
Old Oct 4, 2007 | 10:18 PM
fxlbalto's Avatar
fxlbalto
I do believe that there is a difference in quality of the replacements. have not replaced them on my 06 SD, but have replaced them on some of my other trucks & found that paying premium for the ball joints paid off. The axle bearing suggestion is a good thought too.
Good luck
Old Oct 5, 2007 | 11:33 AM
kinchaser's Avatar
kinchaser
Thanks for the comment. Talked to my service mgr today; he said Ford has had some trouble with these joints and they've supposedly upgraded them. They'll inspect them every service stop so I can at least keep replacing them under warranty, which is some consolation. I'll definitely ask about checking the axle bearing. What 'premium' ball joints did you use?
Old Dec 19, 2007 | 07:43 PM
oltrucker's Avatar
oltrucker
moogs are topof-the line. use synthetic /moly grease for max life.
Old Dec 19, 2007 | 09:06 PM
kinchaser's Avatar
kinchaser
Ball Joints
Thanks for your reply.
C
Old Dec 19, 2007 | 09:33 PM
ken kenmnedy's Avatar
ken kenmnedy
if nothing else get a scound opinion like an independnt front end shop them ford joints aint never gonna last long
boosteddsm
Jun 15, 2011 09:44 PM
bassaway
1983 - 2012 Ranger & B-Series
May 23, 2005 11:00 AM
Zcarbuilder
Aug 21, 2004 09:20 AM
orangeford
Apr 2, 2003 09:11 PM
rdcouch
Sep 15, 2000 10:35 PM
