transmission questions
Old Jan 7, 2012 | 05:26 PM
tsbrewers's Avatar
tsbrewers
Hey all, recently I picked up a '93 E150 4.9L I6 with a bad tranny(unknown to me when I bought it). The tag on the tranny is F2UP-DC. I did a search on car-part.com and found a few at a yard about 2 hours away, so I ran and picked one up. When I was there, I noticed the tag is different on this one and is actually from a '93 F150 with a 5.0L engine. They swear (and guarantee) it will fit. I can barely read the tag on the "new" one, and it looks like it says F21P-DC. Will this fit my van? anything I need to look out for when installing? Thanks for any help I can get.
Brew
Old Jan 7, 2012 | 07:45 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
Those numbers don't mean anything to me. Are both transmissions E4ODs? The one in your truck definitely is, I don't know if the new one is. The AOD is a much smaller trans. E4OD have 20 bolts on the pan, AOD has 14.
Old Jan 7, 2012 | 08:12 PM
tsbrewers's Avatar
tsbrewers
I am pretty sure the "new" one is also an E4OD too. So, if they both are E4OD's, with 20 bolt pans, it should work? anything beyond that I should check for?
Old Jan 7, 2012 | 10:08 PM
Mark Kovalsky
It will work fine.
Old Jan 7, 2012 | 10:11 PM
tsbrewers's Avatar
tsbrewers
Thanks, I appreciate it.
Brew
Old Jan 8, 2012 | 09:44 PM
Club Wagon's Avatar
Club Wagon
Don't know about E4OD, but went thru the mill looking for '92 E150 5.0L AOD tranny. Discovered an issue w/tailshaft length, that prevented an F150 AOD from being a direct fit. Recycler's interchange book said it swapped, but it didn't. Recycler suggested swapping tailshaft & housing, but not practical.
More learned that Lincoln Continental used the right length tailshaft AOD.
Old Jan 8, 2012 | 11:04 PM
tsbrewers's Avatar
tsbrewers
thanks, I will most likely just drop the old one and compare them. The van won't move at all right now anyway, so the old one has to go.
Brew
bradmurd
13
Aug 17, 2008 04:49 PM
velcro7279
Apr 9, 2008 05:50 PM
73F100*8Mile
Jan 13, 2006 08:24 AM
psupoor
Jun 23, 2005 01:51 AM
jpw
May 11, 2004 03:35 PM
