A couple of interior questions
Old 01-06-2012, 01:01 PM
Cory281's Avatar
Cory281
Cory281 is offline
I need to glue my rear view mirror back on. Do I just find where the the middle of the windshield is and put it there?
Also, when my truck was painted they didn't put that plastic sheet in that's in between the door panel and door back in. What kind of adhesive should I use for that? I already have some plastic that I got from Home Depot.
Thanks!
Old 01-06-2012, 01:25 PM
HIO Silver's Avatar
HIO Silver
HIO Silver is offline
Thanks!
Sorta... position the mirror and lower the sunvisors so it clears. Mark the spot and glue it on. Good luck with it... I went through three of those mounting kits after following the instructions to the nth degreee only to find the mirror laying on the dash the following day. My solution was to fabricate a drop-down bracket secured under the center visor bracket.
That's called a water shield. Actually, it should be made of a wax coated paper - not plastic. I used wax paper and secured it with 3M strip caulk... also referred to as "dum-dum". About $11 for a box.
turnrjr
10-02-2018 06:34 AM
Mdc9966
09-04-2015 09:37 AM
Harmonizer2
02-23-2013 08:10 PM
Bonkrr
1997 - 2003 F150
04-06-2012 12:02 PM
cwgoff
1997 - 2003 F150
05-17-2004 09:01 PM
Quick Reply: A couple of interior questions
