Sponsored by: Auxito
Help Replacing Driver's Side Mirror
Old May 17, 2004 | 08:49 PM
cwgoff's Avatar
cwgoff
Well, I caught my mirror on the frame of my garage door as I backed out this afternoon. The mirror will fold back to the door, but it sure doesn't like to fold forward towards the bumper. I now have several pieces of mirror bracket along with a spring. No more driver's side mirror.
Does anyone know how easy it is to replace the mirror bracket? It looks like the mirror itself, along with the housing for the adjustment motors, is still intact. It was hanging by the electrical wires. The plastic bracket that holds it onto the door snapped, though.
Should I be able to find just the bracket at a junkyard, or do folks usually sell the whole unit as a package?
What trim do I need to remove to get to the mounting bolts. I have not looked at it in detail yet, but I figure I will either have to pop off some of the exterior trim around the bracket or maybe even the triangular interior trim module to get at the bolt heads. Has anyone else done this job?
Thanks.
Old May 17, 2004 | 09:01 PM
triton_2002's Avatar
triton_2002
You will probably have a hard time finding just the bracket. The mirror should just have a few bolts on the inside of the door frame. You will need to remove the door panel. Its pretty easy. Pull off the vertical piece at the top, there should be a screw or plasitc rivet there. There is another screw behind the door handle (pull of the trim around the handle or remove handle, not sure on a 97) Then pull off the switch panel and disconect switches. Then the entire door panel comes off by lifting it UP, dont pull it toward you. Hope that helps
hillcountryflt
Nov 3, 2014 11:00 AM
Bret4207
Mar 22, 2014 08:46 AM
str8sixman
Jun 22, 2012 09:00 PM
66F100Again
May 22, 2009 02:59 PM
Hellbore
26
Jun 25, 2006 01:35 PM
