order code 640A
Old Jan 5, 2012 | 08:31 PM
hay is for horses's Avatar
hay is for horses
order code 640A
any ideas what this includes?
Old Jan 5, 2012 | 08:41 PM
aaronbrace's Avatar
aaronbrace
640A is for a XL F350 dually chassis cab (not pickup!). It comes standard with the 6.2L and the 6 speed torqshift.
If you want to see more you can check out the 2012 chassis cab order guide. This should answer a bunch of your questions:
http://profleetsales.com/pdf_files/o...SSIS%20CAB.pdf
---Aaron
Old Jan 5, 2012 | 08:51 PM
aaronbrace's Avatar
aaronbrace
Also, I saw in another thread you were asking about the trailer brake controller. It is not included as standard equipment with 640A. It is an available option (52B) but if it wasn't ordered with it then it won't have it.
---Aaron
Old Jan 5, 2012 | 08:53 PM
hay is for horses
thanks, you are correct it is a cab chassis you guys amaze me on your knowledge!!
Old Jan 5, 2012 | 09:03 PM
hay is for horses
anyway to tell by vin# if it has option 52B?
Old Jan 5, 2012 | 09:18 PM
powerstroke72's Avatar
powerstroke72
Here is a copy of the 2012 Order guide. You can look through it and compare to the truck you're looking at. Also, follow the instructions in this thread:https://www.ford-trucks.com/forums/8...l-sticker.html and you can see the window sticker by entering the VIN number as is detailed in that thread.
Old Jan 5, 2012 | 09:22 PM
hay is for horses
thanks again guys......seems like that I am saying that alot since I joined this forum
Old Jan 5, 2012 | 10:35 PM
kper05's Avatar
kper05
It doesn't end.
I learn stuff all of the time.
Knowledgeable members here.
Old Jan 6, 2012 | 10:54 AM
cirrus365's Avatar
cirrus365
With the VIN we can pull the window sticker.
gump2388
Oct 15, 2019 12:44 PM
trevordog88
6.7L Power Stroke Diesel
18
Jun 2, 2011 09:38 PM
96bigblueford
Feb 15, 2011 07:50 PM
blueheron
Jul 25, 2010 05:08 AM
snakechaser
May 9, 2010 11:22 AM
