94 f150 gear shifter stuck
Take the shrouds around the steering column off, and the instrument bezel, and take a look. If you don't see anything obvious, disconnect the shift cable from the shifter (It's a plastic piece that snaps on to a ball connected to the shifter, and then you can see if it's in the shifter or downstream...
mdjohnson
01-15-2006 12:22 PM
Martys82
03-24-2003 08:24 PM
