Battery Cables
Old Apr 18, 2003 | 01:24 PM
teederj2002's Avatar
teederj2002
Question Battery Cables
I am putting new battery cables on my 1988 f150 and I can't find where the negative cable hooks to. Please Help!
Old Apr 18, 2003 | 01:46 PM
GNORMOR's Avatar
GNORMOR
Battery Cables
Try looking down to the starter. I think mine hooks to the starter houseing.
GNORMOR
Old Apr 18, 2003 | 03:27 PM
mantta's Avatar
mantta
Battery Cables
My 88, 4.9, hooked up to one of the starter mounting bolts. I shortened it and used a bigger cable and hooked it to the alternator bracket. My cranking was slow, my radio would loose memory every time I started it and it would stall from low voltage with the A/C on when I was at idle. Since I done this, I have had no problems at all.
Old Apr 20, 2003 | 01:31 AM
steve83's Avatar
steve83
Battery Cables
It should have an exta eye in the middle that goes to a bolt in the frame right behind the R shock/spring tower. Then on I-6s, it goes to the upper starter mounting bolt. On V-8s, it goes to a stud just behind the lower radiator hose above the oil pan lip. Either is good, but I prefer the starter bolt.
If you can't figure out how to put an eye on the new cable, buy another with 2 eyes about 18" long. Run the main (-) cable from the battery to the starter (or stud if you prefer), then run the 18" one from there back to the frame.
Jodymarshall
Nov 25, 2016 01:21 PM
deshet1980
Jan 5, 2016 05:15 PM
hotweekend
May 29, 2015 06:49 PM
ligito
Apr 10, 2015 08:00 PM
Skyline Drive
Large Truck
Feb 27, 2015 05:54 AM
