Distributor Compatibility
Old Jan 5, 2012 | 04:07 PM
camelchop's Avatar
camelchop
Trailering
Is a distributor from a '92 E150 EFI 4.9L compatible with an older non-EFI I6? Do I just need to change the drive gear? What all is involved? I am working on a build for my stepson and would like to avoid points. I have done some digging and it seems a lot of performance guys on a budget use the Duraspark II package. I have a header and intake manifold from Clifford along with the Holley 390 carb. Looking at investing in a cam upgrade which still respects the 300 I6 being built for torque. Recommendations there? Clifford recommends a 256 it seems. Appreciating in advance....
Old Jan 5, 2012 | 09:30 PM
mark a.'s Avatar
mark a.
When you change a distributor gear or a whole distributor you need to check/set the end play for the gear. If you don't have enough you will loose the cam, block & distributor. I strip the distributor down to just the shaft and housing, tap the gear on and set up a dial gauge on a magnetic stand. Then carefully tap it down and recheck clearance till I get it within .005 -.008 of clearance with it clamped down.
Old Jan 6, 2012 | 08:59 AM
camelchop's Avatar
camelchop
Trailering
I appreciate the words of wisdom Mark. So is the Duraspark II conversion the best solution on a shoestring budget? And will the distributor from the '92 work? Am I looking at a gear exchange?
Old Jan 6, 2012 | 11:48 AM
gfw1985's Avatar
gfw1985
Cranky Old Guy
Your best bet for an answer will be in the six cyl engine forum. As far as Clifford's, I stay away from them period. Poor customer support and too many quality problems I know of. Plus, same parts can be bought elsewhere cheaper. But, just my opinion.
Ed2
Jul 31, 2022 07:33 AM
fstbck1970
Mar 6, 2014 07:07 AM
Hillcapper
Apr 15, 2009 09:15 AM
AllFords1022
Apr 18, 2004 12:49 AM
OneFine69
Dec 28, 2002 01:47 PM
