7.3L Help.
Old Jan 4, 2012 | 05:17 PM
Texascalidrum's Avatar
Texascalidrum
7.3L Help.
I have a 2000 Ford F-250 with a 7.3L Powerstroke in it. Just recently I went on vacation for 2 weeks, and I came back my truck had some problems. When I start up the truck white smoke comes out of the exhaust, the truck also runs like complete crap. It sounds like its running out of fuel, when I know it has plenty. Can I get any help please?
Old Jan 4, 2012 | 05:45 PM
CampSpringsJohn's Avatar
CampSpringsJohn
Welcome to FTE Texascalidrum.
A few questions.
How many miles on the truck?
Have you done the Cam Sensor Recall?
When was the last oil change? What type of oil?
Have you changed the fuel filter recently?
Just coming back from a trip, is it possible that you got some bad fuel?
Where was the last place you got fuel?
Have you cleaned the FPR screen?
How much fuel is in the tank?
Old Jan 4, 2012 | 05:47 PM
CampSpringsJohn
Oh, does the white smoke smell like diesel? Or does it have a coolant smell to it?
Old Jan 4, 2012 | 06:50 PM
F350-6's Avatar
F350-6
Welcome to FTE. Also check your oil level. The fuel injectors fire off of engine oil so we'll ask lots of questions about oil.
Old Jan 4, 2012 | 07:51 PM
izzybird's Avatar
izzybird
Open the valve on the back of the fuel bowl and turn the key on, don't start it. See if you have a good solid stream coming out of the drain. If you can, put a piece of clear tubing on the drain line and make a loop with it then on to your catch container that way you can look for aeration of the fuel. Like CampSpringsJohn said, what does the smoke smell like?
Old Jan 5, 2012 | 11:26 PM
CampSpringsJohn
Any updates????
KRAZY KRAMER
Apr 5, 2013 02:55 PM
matt71
Feb 9, 2010 01:42 PM
jakemb
Dec 9, 2009 06:40 PM
farmer4
Sep 30, 2007 11:55 AM
Dholt
Sep 24, 2003 02:43 AM
