Engine Cleaning
Old Jan 4, 2012 | 03:48 PM
nab101eg's Avatar
nab101eg
Engine Cleaning
I own an '07 SCrew with the 5.4L V8. The engine is very dusty and I want to clean it. Any advice on the best way to do this and any areas that I need to avoid getting wet is appreciated. thanks
Old Jan 4, 2012 | 06:20 PM
danorules's Avatar
danorules
I hose most of it down, fairly regularly. I just stay away from the battery and computer. And when I'm all done I fire up the backpack blower and blow dry the motor
Old Jan 4, 2012 | 07:09 PM
Beechkid's Avatar
Beechkid
spray a 50/50 mix of simple green/water- being carefull to avoid heavy application to any e-connectors. Rinse with hot tap water, apply using an engine cleaning gun that hooks to your air compressor, low water GPM and high pressure to create more of a steam like application....again, avoid e-connections.
Start engine immediately upon completion & bring up to operating temp...although you will see most of the moisture evaporate this will ensure complete drying of all components.
Old Jan 5, 2012 | 01:30 AM
ford-lover's Avatar
ford-lover
I hose down the engine regularly and I cover the brake and power steering bottles with plastic bags. Avoid the computer and the alternator. Start the engine up and take it for a short run to dry up all the moisture.
I am not looking for a perfect detail job so I just use garden hose to wash.
Good luck
Old Jan 5, 2012 | 02:17 AM
ford390gashog's Avatar
ford390gashog
The main issue is filling the spark plug tubes up with water which kills the cop's.
Old Jan 5, 2012 | 07:09 AM
2Fords1Jeep's Avatar
2Fords1Jeep
I found out the hard way. I'd never wash my engine again.
bigds01
Mar 6, 2016 11:58 AM
Iaff113
Feb 7, 2015 07:33 PM
EXbowtieguy
Oct 25, 2011 11:16 AM
red dog
2004 - 2008 F150
13
Apr 23, 2010 08:38 PM
Champ
2004 - 2008 F150
Nov 29, 2004 10:31 PM
