cleaning all the sand from engine compartment
Old Apr 14, 2010 | 09:48 PM
red dog's Avatar
red dog
I live in iowa and after the winters there is sand on the battery, valve covers, and here and there. Ive been using compressed air and that helps some but, wondering about thoughts of the power washer from a distance so it gently sprays the sand away. Ive heard horror stories of sensors being ruined. Any suggestions either way?
Thanks, red dog
Old Apr 15, 2010 | 03:06 AM
ford-lover's Avatar
ford-lover
I wash my truck's engine compartment regularly with a garden hose and so far did not encounter any problems. I usually cover the alterator, the brake and power steering bottles with a small plastic bag. I also keep my spray away from the ECU. I never dare to use power washer because it may be too strong to push the water into connectors and sensors.
This is just my opinion.
Old Apr 15, 2010 | 03:52 AM
gearloose1's Avatar
gearloose1
There is no good way.
Water is needed to wash away salt.
So you have to ask yourself ... what is your poison.
Stay away from harnesses, connectors (where water may be forced in).
Use a light garden hose rinse to wash those of salt.
Old Apr 15, 2010 | 11:45 AM
Joe04F150's Avatar
Joe04F150
When the engine is cold I spray some simple green around, let it sit 2-3 minutes and then rinse with a garden hose...grab my backpack blower and airdry the complete compartment...done!
Old Apr 15, 2010 | 04:06 PM
2004 xlt 5.4's Avatar
2004 xlt 5.4
Make sure you dry the spark plug holes as water in them may cause missing
Old Apr 15, 2010 | 08:17 PM
danorules's Avatar
danorules
i clean my engine compartment all the time with the garden hose and no problems. I do like the back-pack blower idea also. that should get the neighbors scratching their heads saturday morning
Old Apr 16, 2010 | 10:48 PM
red dog's Avatar
red dog
Many good ideas, thanks guys.
Old Apr 16, 2010 | 10:53 PM
Roller150's Avatar
Roller150
The owners book also shows you what parts to cover with plastic. Its only two things and I can remember off hand, other than that you are good to go.
Old Apr 17, 2010 | 05:39 PM
soundwave's Avatar
soundwave
If its not good to spray the engine down, why is there the "engine cleaner" option at the do-it-yourself carwashes? That uses a pretty hard blast of water along with some solution.
Old Apr 21, 2010 | 10:21 AM
danorules's Avatar
danorules
just because something is an option does'nt mean that it is good to do
Old Apr 21, 2010 | 12:24 PM
Gearbanger 101's Avatar
Gearbanger 101
I've never had an issue with using a pressure washer in the engine bays of any of my vehicles. I start with the vehicle at full operating temperature and leave it running while doing so. The warm engine compartment helps evaporate any excess water so it isn't allowed to become stagnant and seep into area's you really don't want it to.
As stated, keep electrical components out of the stream of direct high pressure water and you really haven't much to concern yourself with.
If it’s really cruddy, feel free to spray the engine with some form of degreaser first, but make sure you've thoroughly rinsed it off. I imagine the grease cutting power of some of these industrial strength cleaners would be more corrosive than any amount of salt when allowed to linger on electrical components.
I used to use a product called Purple Power years ago to cut the heavy grease. Not sure if they still make it though?
Old Apr 22, 2010 | 08:00 PM
FTE Trigger's Avatar
FTE Trigger
I used to clean my '99 Ranger's engine compartment the same way Gearbanger mentioned above, but I would try my hardest to keep any cleaning solutions away from the belt.
Past personal experiences has landed me with a belt that popped off (while @ the car wash) and got entangled in my fan and bent up both trans-cooler lines.
Good thing I kept spare belts and my serpintine belt wrench in the tool box...
Old Apr 23, 2010 | 07:51 PM
cgah04's Avatar
cgah04
i gave up on that.. i live near the beach and constantly take my truck on the beach. ahhh sand! think my truck just got used to running around with sand everywhere
Old Apr 23, 2010 | 08:38 PM
BlueOvalFitter's Avatar
BlueOvalFitter
Thumbs up
When i'm done cleaning my engine I let it idle for about 10 minutes.Then I spray everything down with silicone spray.I wipe off the excess with a rag.This gives everything that new look and leaves a coat of protection on everything.
Turbo Dog
Dec 13, 2022 10:33 PM
sand1
Feb 28, 2017 02:09 AM
1950f1ca
Feb 12, 2017 08:01 PM
NYcoop
1983 - 2012 Ranger & B-Series
18
Mar 7, 2016 08:16 AM
spit fire
Computer Chips & Tuners
Mar 16, 2010 07:43 PM
