EBP question
Old Jan 4, 2012 | 02:10 PM
critterf1's Avatar
critterf1
EBP question
What is considered "normal" EBP reading at idle? 2003 6.0 F-550
Old Jan 4, 2012 | 04:59 PM
npccpartsman's Avatar
npccpartsman
An 03 with any kind of dealer flash after sometime in 05, IIRC, doesn't use the EBP sensor. It's an inferred value.
Old Jan 4, 2012 | 06:17 PM
critterf1's Avatar
critterf1
Should it even show up on my scanner? I'm showing 0.00 KOEO, 34.00 or so at idle and anywhere between 250 and 300 in between the "farts" and the "surge"
Old Jan 4, 2012 | 08:28 PM
cheezit's Avatar
cheezit
03 would show as epbg and is a very different reading. all calculated.
Old Jan 5, 2012 | 09:26 AM
critterf1's Avatar
critterf1
OK, thanks. Maybe you can help me with this problem. Truck came in on the "hook" with a broken exhaust rocker arm. Replaced assy and truck idles like a new one. Took on test drive and it had no power set code 2262. Re-conditioned turb and replaced MAP and VGT, performed re-learn procedure and test drove. No power, black smoke and the turbo farts. Cleaned EBP tube and replaced sensor, same problem. Re-installed old MAP sensor, No farts, no smoke and no power. What am I over-looking? Ready to pull my hair out!!!
Old Jan 5, 2012 | 07:35 PM
critterf1's Avatar
critterf1
I could really use some help fellas
Old Jan 5, 2012 | 08:02 PM
cheezit's Avatar
cheezit
check vref shorts and also look into dtc p0046 as a possible pinpoint test to go off of. may also be related to a concern with pinpoint test p.
load tested any circuits yet?
Old Jan 5, 2012 | 08:17 PM
critterf1's Avatar
critterf1
I have 11.5 volts at the VGT connector, my scanner is unable to command the solenoid to open and close.
Old Jan 5, 2012 | 08:20 PM
cheezit's Avatar
cheezit
check the pigtail for it. your stuck over fuel. so let me restate the above. laod test the circuits as needed and check for vref shorts and the like.
also check the load pid at idle
Old Jan 5, 2012 | 08:29 PM
critterf1's Avatar
critterf1
10-4. Thank you
Old Jan 6, 2012 | 03:51 AM
npccpartsman
One simple thing to check: When you replaced the MAP sensor did you clean the hose and the nipple on the intake that the hose fits on? Sometimes they get clogged from crap in the intake and won't allow the MAP to read. Also, MAP and BARO should read virtually identical at KOEO.
Old Jan 6, 2012 | 05:06 AM
critterf1's Avatar
critterf1
Replaced hose and cleaned nipple, MAP and BARO read identical KOEO
af11
Apr 20, 2014 10:38 PM
djanzen
Sep 16, 2013 07:47 AM
duck fan
Jul 26, 2011 03:09 PM
Canine 582
Dec 24, 2004 01:26 PM
flounder
Jan 12, 2004 06:44 PM
