Advice: Proper frame cleaning
Old Jan 3, 2012 | 07:51 PM
jtindale's Avatar
jtindale
Hello,
I am in the process of getting my frame cleaned up now for painting. I have stripped everything off the frame and have pressure washed it, used degreaser on it and also a over cleaner. There's not a spot of oily residue left on the thing.
Right now I'm trying to get the paint and rust off of the frame. I used a 80 grit flap disc on my angle grinder and that gets the paint and rust off great all the way down to shiny metal. I then used a wire cup brush and that work great too and lasted a whole lot longer. The problem with the wire cup brush is the metal has a dull grey finish to it rather than the flap disc which was shiny. Is the dull grey finish part of the paint the wire cup brush is not removing? Do I need to get down to the shiny metal or is the grey dull part sufficient?
Which process is recommended?
Here's what the two sections look like.
Old Jan 3, 2012 | 11:25 PM
Bill W's Avatar
Bill W
Good Job!
it really depends on what you plan to use as a top coat, the wire brush method will leave a residue behind that should be cleaned off before you paint it. bad thing about the flapper wheel is if your not careful you will see all kinds of grind marks once you paint it.
So.... what are you going to top coat with?
Old Jan 4, 2012 | 05:36 AM
jtindale's Avatar
jtindale
Originally Posted by Bill W
Good Job!
Thanks Bill!
I plan on coating with an epoxy primer and then a poly enamel topcoat.
If I go the wire brush route do I wipe the frame off with mineral spirits to clean the oily residue?
Old Jan 4, 2012 | 06:49 AM
gfw1985's Avatar
gfw1985
Cranky Old Guy
No matter which method you use, you should wipe down with degreaser before painting. This applies to painting anything.
Old Jan 4, 2012 | 05:23 PM
jtindale's Avatar
jtindale
Thanks gfw1985 and good point. I'll give everything one last degreasing before I paint.
Old Jan 5, 2012 | 12:08 AM
teds74ford's Avatar
teds74ford
Not that I do show quality stuff, but my method is as follows:
Use a wire brush
Clean with harsh dish soap, warm water and a scrub brush
Rinse and let dry/blow dry
Wipe with mineral spirits and then paint.
The dull look from the wire brush is fine. It is a good cleaning, it just isn't shiny.
NewClimber
16
Oct 31, 2017 08:19 AM
william16339
Oct 2, 2014 07:27 PM
darren_palms
21
Mar 12, 2014 07:31 PM
Can DO
Oct 28, 2008 05:40 AM
mallard8767
Appearance & Dress-Up
Dec 21, 2004 11:29 AM
