Frame Paint
Old Mar 10, 2014 | 08:21 PM
darren_palms's Avatar
darren_palms
Frame Paint
I'm stripping down a 1979 3/4 ton frame and going to paint it. I'm just going to wire wheel it instead of sandblasting it ( for money and mess reasons) and I'm trying to figure what type of paint to use. I'm looking for a functional paint job to prevent rust and affordable (doesn't need to be showroom quality). Ideas and recommendations? Thanks.
Old Mar 10, 2014 | 08:36 PM
51fordf5's Avatar
51fordf5
When I was doing my frame, I wire wheeled it too. Then I used rustoleum rusty metal primer in my cheapo HVLP gun and hit the frame with a few coats, and then did a few coats of rustoleum flat black on top of that. I live in Illinois and it has not been a good winter, lots of snow and tons of salt on the roads and I daily drive my Ford. The frame still looks good, I just washed it today and it's holding up great.
Old Mar 10, 2014 | 08:46 PM
Blue and White's Avatar
Blue and White
Red Rustoleum primer and black Rustoleum finish works well for me also. I think I used semi gloss finish but same idea. I used a needle peener to clean mine but same idea as wire wheel. If you have a decent air supply the HF needle peen gun works well.
Old Mar 10, 2014 | 08:54 PM
HIO Silver's Avatar
HIO Silver
POR-15 or Eastwood's Rust Encapsulator... a little goes a long way when brushed.
Old Mar 10, 2014 | 08:59 PM
kwe45919's Avatar
kwe45919
I used Tractor Supply "Majic" Truck, Tractor and Implement paint. Everything came down to the bare metal, rustoleum primmer, 3 coats and then 2 coats of the black paint. No clear is needed unless desired. I'll see how it holds up over the next few years. Did the bottom of the cab and I plan to do the bottom of the bed as well. Looks great right now but I know dirt, rocks and salt over the next few years will chew it up a bit....it won't look good forever....
Old Mar 10, 2014 | 10:50 PM
Undertheoaks's Avatar
Undertheoaks
I used KBS seal and cleaning products very tough finish...so tuff a hammer did no chipping to it when I tested it out. I sand blasted and wire wheeled mine.
Old Mar 11, 2014 | 09:08 AM
Toodugs's Avatar
Toodugs
Zero Rust
These guys have a good product and comes in several colors. It's not "just paint", it's made for bare metal base coat rust prevention.
Zero-Rust
Old Mar 11, 2014 | 09:39 AM
trozei's Avatar
trozei
Many people will tell you to go with Rust Bullet, POR-15, Chassis Saver, and other rust encapsulators like such. Their design is to be painted over surface rust to cover it and seal out moisture and oxygen to stop the rust from getting any worse, much like a self-etching primer. If you're leaving surface rust, this is the way to go.
If you're going down to bare metal, don't use the rust paints. Sometimes they don't adhere properly due to the lack of rust and quite frankly you'd be wasting your money because of how expensive they are.
Bare metal? Epoxy primer and Rustoleum (or Tremclad if you're Canadian like me). Do it properly and it will last years and it will not break the bank very much at all.
I would suggest you use a proper paint gun hooked up to a compressor to do this, but whatever you do, don't forget to completely degrease the surface before applying any form of paint.
A paint job is only as good as the prep work behind it.
Old Mar 11, 2014 | 09:51 AM
'78F250351m's Avatar
'78F250351m
Chassis Saver
Old Mar 11, 2014 | 09:56 AM
darren_palms
Frame Paint
Thanks for all the advice...like I said I will wire wheel it so there could be minor rust here and there.
Old Mar 11, 2014 | 10:32 AM
trozei's Avatar
trozei
Are you planning to use a rust encapsulator or just a normal paint? Either will work but if you use paint I suggest a self-etching primer.
Old Mar 11, 2014 | 08:34 PM
kwe45919's Avatar
kwe45919
Yes sir...prep is very important as well as the products and tools. I figured with everything welded and seam sealed on the bottom of the cab, I'd better protect all that hard work the right way the first time.
Old Mar 11, 2014 | 10:39 PM
jtindale's Avatar
jtindale
I wire wheeled my frame, too. Then I sprayed a rust converter on any light rust left behind or on any areas I couldn't reach with the wire wheel. After that I used epoxy primer and paint on top. Nothing will seal and bond like epoxy primer but at the same time it won't have the hardness properties of some of the chassis paints mentioned above.
Old Mar 12, 2014 | 01:09 AM
trozei's Avatar
trozei
Psst... you're supposed to paint over the primer.
Old Mar 12, 2014 | 01:39 AM
bucks77ford's Avatar
bucks77ford
Chassis Saver is a good paint, but really only holds up to sandblasted or rusty metal. I have used the crap out of it and believe it or not, it does hold up well on rusted metal. As long as the flake and scale rust is brushed off and have a solid rust to adhere to, it works great. I have painted over rust and then had to sandblast it off and the paint was kind of a pain to blast off. I have used it on bare metal ground down without blasting and it does not hold up well.
