Sterling Disk brake conversion...stuck calipers
Old Jan 6, 2012 | 07:17 PM
Franklin2's Avatar
Franklin2
Have you finished doing the troubleshooting yet? You should know if it's the proportioning valve. Since the brake system is not original anymore, I would take it out also.
Old Jan 7, 2012 | 06:13 AM
kaotikedge_111100's Avatar
kaotikedge_111100
No I haven't made time to get out there yet, I'm hoping to get it figured out by this weekend. I'm willing to bet its the pv, ill keep this updated once I figure it out.
Old Jan 10, 2012 | 09:07 AM
kaotikedge_111100
So I got the truck fixed....and I was betting against the Proportioning valve being the culprit.....I was WRONG!!
I decided to check all the mechanical things one last time before tearing into the hydraulics and the Proportioning valve.
What I ended up finding was once the lug nuts were tightned down they were basically clamping the rotor and the brake pads together. I spaced out the things out with some 1/8" spacers between the rotor and the hub. Now everything spins super smoothly after the lug nuts are torqued down.
Long story short, if you are using the RuffStuff brake caliper mounts make sure you check which year Sterling Axle you have because you may need spacers...or read their website...because I didn't.
During the conversion process I also swapped in Front F350 brakes and the F350 master/booster. After driving it with everything working the way it's supposed to I am EXTREMELY impressed with the stopping power this truck has.
Thanks again for everyones help!!
Old Jan 10, 2012 | 09:14 AM
Cavstoy's Avatar
Cavstoy
I did a similar rear disc conversion in a toyota landcruiser and there was a small device I had to remove to alleviate pressure in the rear lines. It did the exact same thing you described with your bronco before removal. Also, I think a disc/drum master is ok...seen it done lots of times retaining the stock master. That is my 2¢.
Looks like it is solved
Chris Ratcliffe
Apr 23, 2013 10:04 PM
DLHudson
Oct 15, 2010 08:41 PM
hap0113
Apr 30, 2007 05:46 PM
78 F150 Custom
Sep 11, 2003 03:53 PM
1sscav
1978 - 1996 Big Bronco
Mar 6, 2003 05:10 PM
