1978 - 1996 Big Bronco
braking problem
Old Mar 6, 2003 | 08:23 AM
1sscav's Avatar
1sscav
Question braking problem
I'm having a problem with my '92 Bronco's brakes. Every once in a while the pedal will not depress, and it feels like its jammed. Keeping pressure onit will usually get normal brake pressure and brake acion afte 3-4 secs, but in traffic that can get hairy.
I've replaced the valve on the power booster, the master cylinder, pads, rotors and calipers. Plus a computer check shows no faults. I'm at my wits end. Any thoughts?
Thanks.
Old Mar 6, 2003 | 12:29 PM
Kemicalburns's Avatar
Kemicalburns
braking problem
did you bleed the system properly. you need to start from the tire farthest away from the power booster and work your way forward making sure that you have gotten all the air out of the lines.
Old Mar 6, 2003 | 01:30 PM
1pump's Avatar
1pump
braking problem
If a proper bleeding doesn't fix it, it might be your booster. Also, master cylinders need to be bench-bled before they're installed.
Old Mar 6, 2003 | 03:23 PM
Tahoe1990EB's Avatar
Tahoe1990EB
braking problem
1pump...or someone else....
If master cylinder was not bench bled, do you know the remedy for that? (My braking has been a bit off since my new master cylinder was installed by a little hokie shop-I doubt they bench bled the master cylinder)
Old Mar 6, 2003 | 05:10 PM
1pump's Avatar
1pump
braking problem
A lot of people don't bench bleed, and sometimes they get away with it. And sometimes they don't.
A decent auto parts store will have a bench bleeding kit, consisting of some tubing, some cute little plastic adaptors for the ports on the master cylinder and instructions.
I used to sell them under the Raybestos brand, but anybody should have 'em. Usually less than $10. In some cases, they would come with new (not reman) masters. Good way to avoid a comeback on a "bad" master cyl.
I've seen some mechanics bleed the master on the car without a kit. It works, but it'll squirt fluid all over the place.
norust
Nov 17, 2016 09:20 PM
Technologiq
Jun 28, 2015 05:05 PM
jglee
23
Oct 1, 2010 11:11 PM
russt
Nov 20, 2004 10:53 PM
quent
Electrical Systems/Wiring
Sep 6, 2004 08:21 PM
