It's been a while since I've been on here... lots of stuff going on!
Anyways, I was traveling down the interstate a few days ago and I noticed the my cruise kicked off and my parking brake light turned on. I thought that was a little weird as I haven't touched the brakes in the last 100 miles or so. I pulled off the interstate and it appears that I lost any assist to the brakes. The pedal depresses an inch of two and then it's solid.
So I'm guessing the master cylinder went out? What is the process for replacing it? I know they can be somewhat a pain as you have to bleed the cylinder and the brakes.
You will need a power steering pulley puller, after that I think the ax pump must come out. Then it just swap out. My hardest part was putting the pulley back on the shaft.
Remove belt and the old pump
Use a pully puller/intaller and pull the pully(auto parts store should loan)
Remove the bolts
Just be sure to remember to install the bolts before the new pully is pressed back on.
Press pully on
And put it all back.
10mm wrench
Edit add on
My pc connection must be slow. What Doug said lol
