Injectors sticking
Old Jan 2, 2012 | 07:55 PM
fordpride's Avatar
fordpride
Injectors sticking
I got my stageI's used and on a cold start(sitting 8-10hrs) when I start it I'm only running on 6-7 cylinders til it warms a bit or I start revving it and then it'll fire on all 8. What's the deal?
Old Jan 2, 2012 | 07:58 PM
Talyn's Avatar
Talyn
Sounds like a wiring issue.
But then, how long have you drove it after install?
Could still be air in the system.
Old Jan 2, 2012 | 07:59 PM
Action4478's Avatar
Action4478
If you feel up to it , pull the covers , one or two will not be spitting oil ... (poppets)
On edit . T has a point . How long have they been in there ?....
Electrical will usually set a CEL ...(or at least a soft IDM code) ...
Old Jan 2, 2012 | 08:04 PM
fordpride's Avatar
fordpride
I've put about 300 miles on them. When I try to do a buzz test when cold it buzzes real low then fires 1,2,3 and stops.
Oil has 200 miles on it
Old Jan 2, 2012 | 08:08 PM
fordpride's Avatar
fordpride
If it was wiring why would it clear up after I rev it a coue times
Old Jan 2, 2012 | 08:10 PM
Talyn's Avatar
Talyn
Resistance in metal changes with temperature.
Might not be getting good contact with solenoids till it warms up.
Thats all I was thinking.
Old Jan 2, 2012 | 08:28 PM
fordpride's Avatar
fordpride
I'll check the wiring.
When it get warm it'll run like a raped ape.
If it's a poppet how hard would it be to swap the pistons to different injectors?
Old Jan 2, 2012 | 08:30 PM
Action4478's Avatar
Action4478
If it is a poppet issue , they need to be machined or replaced ...
Old Jan 2, 2012 | 08:37 PM
fordpride's Avatar
fordpride
I have a good set of injectors couldn't I just swap the stageI pistons to the good stock injectors ?
Old Jan 2, 2012 | 08:40 PM
Action4478's Avatar
Action4478
IIRC , its the seats that get hammered ...
Christof13T
Jun 14, 2012 02:31 PM
F350-6
Dec 2, 2011 09:30 PM
Ratkat
Feb 1, 2011 07:58 PM
superwrench1474
Jul 7, 2010 08:50 PM
1950gmcelc
30
Jan 22, 2010 07:59 AM
