1949 C.O.E. questions.
Old May 31, 2016 | 07:52 PM
Bowsandovals's Avatar
Bowsandovals
Oh I have many questions. I picked up this 1949 F6 coe down in Oklahoma. The minute I saw it I loved it. It is actually in great shape and it ran. However, the brakes needed attention. I replaced the front brake cylinders and in doing so also had to have custom rubber lines made going to them. No biggie. The master cylinder was junk and leaking so I replaced that. I bled the brakes and adjusted the shoes untill they were just barely dragging and bled again. The problem is, I can pump the brakes and get a hard pedal and it will hold, but when I let off, it goes to the floor when I step on the pedal again. I am now at a crossroads where I decide if the slave cylinder is bad, booster is bad,(the booster sometimes kicks back) or if I should scrap the old master cylinder setup and go with something a little more modern and separated front/rear.
Old May 31, 2016 | 07:58 PM
Bowsandovals
This truck has the flathead v8 and the 2 speed rear dif.
Old May 31, 2016 | 08:02 PM
Bowsandovals
This is the Rube Goldberg setup on the firewall for vacuum.
Old May 31, 2016 | 08:03 PM
Bowsandovals
This is the master cylinder, slave cylinder, booster.
Old May 31, 2016 | 08:06 PM
Bowsandovals
I am wondering if there is maybe a check valve or recovery valve in the slave or elsewhere that is not working? Any help from you guys that have been through all this in your restos, would be greatly appreciated. I have a manual on order from ebay and that may help me troubleshoot.
Old May 31, 2016 | 08:52 PM
38 coupe's Avatar
38 coupe
How are you bleeding your brakes? I have bled brakes with two people, one at the brake peddle and one at each slave cylinder. If you are bleeding solo you are probably not getting all the air out of the lines.
Thanks for posting all the pictures right out of the gate. Nice looking truck.
Old May 31, 2016 | 08:58 PM
abe's Avatar
abe
Welcome to FTE! This is the best Ford Truck Forum on the World Wide Web!
I can't help you with your brake problem but I do know that guys will want to see more pics of your truck and a story about it. Thanks!
Old May 31, 2016 | 11:19 PM
pweng1's Avatar
pweng1
Your rear brakes should have 2 wheel cylinders. Make sure you are getting brake fluid in the secondary wheel cylinder and air is not trapped. I would bleed the booster too i think it is the problem.
Old Jun 1, 2016 | 12:38 AM
52 Merc's Avatar
52 Merc
Welcome to the forum! Cool COE you found. Having a truck that's running and semi-driving puts you farther ahead of many of us here. FYI, in case you hadn't investigated that far, the "Rube Goldberg" vacuum setup on the firewall also actuates the 2 speed rear end unit. Have fun with your project.
Old Jun 1, 2016 | 02:44 PM
Mixer man's Avatar
Mixer man
Welcome to FTE. Beautiful truck.
That isn't a Rube Goldberg thing under your hood. It serves a means to supply engine vacuum to shift the two-speed axle (the cable is missing from the dash), to shift the two-speed speedometer transmission, and supply vacuum to the brake booster, which according to your pic is not the original Kelsey-Hayes. My F-6 has single rear brake cylinders.
Old Jun 1, 2016 | 07:28 PM
Bowsandovals
Cool pics. I have not taken the rear drums off yet. The inside dual is marinating in PB Blast. I am pretty sure mine only has one brake cylinder per side. I bled the brakes in this order. Slave cylinder, rt rear, lt rear, rt front, left front. My 2 speed rear end has a cable going to it leading to a red pull **** on the dash.
Old Jun 1, 2016 | 07:31 PM
Bowsandovals
I propped the truck up on jack stands and spun the wheels and adjusted the shoe drag to the drums. Then I ran the truck in first gear. When I get the brake pedal pumped enough to have pressure, all of the wheels stop.
Old Jun 1, 2016 | 07:39 PM
Bowsandovals
Does anyone have pictures of the dual brake cylinder setup? I have not worked on this thing for a week because I am stumped. It has been a learning experience. When I first got the truck last fall, it ran smoothly at idle but sputtered in higher rpms. The carburator was missing gasket material so I sent it to a friend who restores vintage carbs. It turned out awesome but I still had the sputter. Thats when I got my learn on about the loadomatic carb. The plate was rusted and the vacuum advance was unable to move it. BP Blast to the rescue. So now it is the brake problem that stands in the way of trying out the 2 speed rear dif. Just for info, this truck was already converted to 12 volt.
Old Jun 1, 2016 | 07:49 PM
Bowsandovals
Sorry I did not address your post right away, I have my brother pump the brakes till there is pressure, then I crack open the bleeder screw on the wheel cylinder until the pedal hits the floor, tighten then repeat. I should invest in an air power bleeder eventually but this works for now.
Old Jun 1, 2016 | 07:51 PM
49fordv8f4's Avatar
49fordv8f4
That is a very nice looking COE! The F4-F6 '48-'52 all have the same brakes, with a single wheel cylinder at each wheel. I believe some of the F7-F8 trucks had dual rear wheel cylinders as well as some of the later trucks. Your booster looks like a Midland booster which could be original to the truck.
Mark
