Tips or advice before I begin
Old Jan 4, 2012 | 09:54 AM
DanCampbell's Avatar
DanCampbell
Sounds good, thanks.
Old Jan 4, 2012 | 10:59 AM
Phy's Avatar
Phy
Regarding moving to TDC for glow plugs:
When I did mine, I didn't know what brand of GPs were in it, and was worried... I decided to start changing them, and if I ran into one that started to bind up during removal, I'd then move that piston to TDC. I got lucky, as all the GPs were Motorcraft, and came out with no problems.
Old Jan 7, 2012 | 07:19 PM
DanCampbell
Ok
Got the first glow plug out before it got dark
its a champion.
any tips for getting the connectors off? The first one was tough an I used channel locks.
any tips would be great.
Thanks
Dan
Old Jan 8, 2012 | 07:04 PM
DanCampbell
All done
Glow plugs and return lines.
Now I can't start the truck because the batteries are dead.
I did too much cranking trying to start it before I replaced everything.
The plugs came out OK, they were Champion.
Thank for all the help guys!
Dan
Old Jan 12, 2012 | 07:51 AM
DanCampbell
Done,
Truck started fine and I drove it to work today (1 hour ride)
Thanks for everything guys.
Old Feb 18, 2012 | 07:47 PM
whiteboyslo's Avatar
whiteboyslo
If you have any tips/tricks from these jobs you could share, please do. I'm about to replace glow plugs and the return lines on mine soon, and it will be my first time doing this job. I'm a bit nervous.
drewdole
Mar 18, 2011 09:25 PM
badasblue
Feb 11, 2010 11:36 PM
ford 5ver
25
Apr 11, 2009 08:55 PM
firebug
Jan 20, 2007 09:07 PM
FarmboyAC
Dec 28, 2004 05:12 PM
