Can't get defrost to work.
Old Jan 1, 2012 | 06:23 PM
Sw1tchfoot's Avatar
Sw1tchfoot
Hello,
I can't seem to get the defrost to work on my (factory A/C equipped)truck. Off turns everything off, Mix makes heat come out at the floor and vents. When put to "Floor" the thing under the dash opens farther allowing more air to come out at the floor, but it still blows out the vents. Defrost still blows out the vents. A/C seems to work, I hear something and the fan changes tone. (I don't have a compressor or anything)
No matter where I put it I can't feel any air blowing out the dash, I even unhooked the vacuum line that runs into the cab and it still blows from the vents. Manually, what does it take to make the defrost work, like can I put my hand under the dash and do something just so I can actually feel the air? Would it be useful to remove the dash pad or does that not provide any more visibility..?
Old Jan 1, 2012 | 07:23 PM
ctubutis's Avatar
ctubutis
Removing the dash pad offers GREAT visibility & access, I haven't had mine installed for years for that very reason.
Removing the glove compartment and radio also sometimes helps, too.
Old Jan 1, 2012 | 07:43 PM
84-6.9L's Avatar
84-6.9L
Mine has been doing the same, the way it seems to me is the VENT door is hanging up, on mine if I don't use the vents for a few days and go bouncing down the road the door will close, once closed if you slide your selector very quickly to defrost so the vent door don't accuate you will have defogs. I haven't gotten around to taking the dash apart yet. Could be one of 2 things, there is foam from the door seals stuck in there, or the hinge my have broken or come loose from what I have been told.
Old Jan 3, 2012 | 02:49 PM
1986F150six's Avatar
1986F150six
Sw1tchfoot,
I just did a quick search and found three threads which will be of assistance.
Heater Blend Door Gone Bad - Calling NumberDummy [11/21/2011]
HVAC problem [7/30/2011]
HVAC vent / door problems (WAS: my 86 F250 haunted) [11/12/2010]
Old Jan 3, 2012 | 07:32 PM
Sw1tchfoot's Avatar
Sw1tchfoot
Thanks everybody, i'll do some more reading and trouble shooting..
Old Jan 3, 2012 | 08:50 PM
dmanlyr's Avatar
dmanlyr
Very common problem. Assuming you have verifed that the vacuum motor is moving the link rod (and I have never seen one of these fail) The vent door hinges have failed, they are just a plastic material. Pull the glove box, pull the cover off of the heater box and you will have enough room to access the door area and replace it. You have to spread the heater housing a little bit as well. All in all not a hard or bad job at all.
I beleive at this late date these are obsolete, but I bet Number Dummy can find one for you.
David
fordboy2
Dec 13, 2017 07:19 PM
beetle
Dec 16, 2013 11:47 AM
esrink
Mar 10, 2008 09:32 PM
aka rotten
Nov 27, 2006 10:36 AM
Elmer Fudge
1997 - 2003 F150
Jul 9, 2004 06:27 PM
