3G alternator and battery problem
Old Jan 2, 2012 | 08:50 AM
nlareau's Avatar
nlareau
Took me a long time to learn that when you don't know what you are doing that it is best to ask somebody that does know what they are doing. The really hard part was learning to SHUT UP and LISTEN to what they'd tell me. Turns out to usually be a good method for learning.
Wish I'd have known this trick when I was 16.
Old Jan 2, 2012 | 12:07 PM
nlareau's Avatar
nlareau
wow.. didn't expect this one
Fixed the SOB!
Here's the part I didn't expect. Pulled the schematics, found the right grn/rd wire and made the right connections (finally). That didn't fix it all.
Here's the 2nd idiot mistake I made. My truck has a non-standard alternator bracket. It is from MAPCO made to also hold an A/C compressor. Because of that, I can't use a standard lengh V-belt, it needs to be longer (45").
I installed a 45" belt that was .65" wide. WRONG!. The belt should be .5" wide. The belt had eaten itself into the .5" pulley but that left a lip .15" wide on the the outer edge. THAT .15" EDGE KEPT THE BELT FROM SEATING. It was slipping like crazy and I didn't know it.
Thanks for all the help guys. I'm glad to have this back running solid.
Old Jan 2, 2012 | 12:37 PM
mikeo0o0o0's Avatar
mikeo0o0o0
Congratulations on getting her fixed.
Yeah, that's a lesson (shut up and LISTEN) that a lot of people could benefit from.
Sweet, the stock ammeter even works!
Old Jan 3, 2012 | 02:39 PM
cabloom300's Avatar
cabloom300
I know you cant really see the colors but is the wire on the right the red/green wire that i need to tie into? It doesnt seem like it connects to the solenoid but its the only red/grn wire that was disconnected from the old wiring. Thanks for the help
Old Jan 3, 2012 | 03:06 PM
Bullitt390's Avatar
Bullitt390
Certified Thread Hijacker
Yes, that be it.
Josh
Old Jan 3, 2012 | 03:36 PM
cabloom300's Avatar
cabloom300
Thanks Josh! Hoping to have this thing up and running soon, il be sure to stop by again with any questions, Thanks again
kincfu
Apr 3, 2017 11:08 PM
patclem
Aug 21, 2015 09:39 PM
SideWinder4.9l
Dec 13, 2014 02:22 PM
BaronVonAutomatc
Electrical Systems/Wiring
May 3, 2007 10:23 AM
Psyte
Jan 23, 2006 01:15 PM
