Charging System Problem
Old Mar 28, 2017 | 03:09 PM
kincfu's Avatar
kincfu
Hello,
I have a 2000 E150. New battery and new alternator but the battery is not receiving charge. Alternator tested good at the store. Battery purchased at Costco 2 days ago and tested good in holding charge.
What could have gone wrong?
Thanks.
Kin
Old Mar 28, 2017 | 04:09 PM
vettex2's Avatar
vettex2
a bad connection, broken wire.......
Old Apr 1, 2017 | 02:59 PM
kincfu's Avatar
kincfu
Check all wiring and connection, all good. Just not enough voltage (11.7v).
Could it be the belt (replaced 8 months ago) or the belt tensioner?
Old Apr 1, 2017 | 06:12 PM
vettex2's Avatar
vettex2
is it slipping?
quick test but not Ford approved, spray some Hi-tack on the belt.
Old Apr 1, 2017 | 11:11 PM
kincfu's Avatar
kincfu
Belt not slipping but can be pushed in almost an inch.
Old Apr 2, 2017 | 10:24 AM
Conanski's Avatar
Conanski
What is the back story? Did this problem just show up and the van was running fine before? Or did you just purchase the van with this pre existing problem?
FYI.. those bench top alternator tests are notoriously unreliable.
Old Apr 2, 2017 | 07:09 PM
kincfu's Avatar
kincfu
Van was running fine until now. Old alternator bearings were worn out. Got replacement for it then it is not charging.
Old Apr 2, 2017 | 09:38 PM
jimbomitch's Avatar
jimbomitch
Good possibility your replacement alternator is defective. Seen this happen more than once. A friend of mine bought a new GM alternator, didn't charge so he took it back for a replacement, still not charging. We went nuts trying to figure out what the problem was. So for the heck of it he bought a rebuilt one, and it cured it. Yup, two bad alternators, new, not rebuilt.
Old Apr 3, 2017 | 11:34 AM
98Econoline150's Avatar
98Econoline150
Best way to test the alternator is to take a multimeter and set it to DCV. Start the van and let it warm up. Then uncover the "field" connection which is the rubber boot coming out at the top rear of the alternator. Place the red lead on the meter to the "field" and the black lead on the positive battery post. If it is less than 12 volts the alternator is not charging.
Old Apr 3, 2017 | 09:05 PM
kincfu's Avatar
kincfu
On the back of the alternator is the +Black/orange big cable; then there is a plug with white, orange w/grey, green w/black, which one is the wire responsible for exciting the alternator to charge?
Old Apr 3, 2017 | 11:08 PM
98Econoline150
The big black and orange cable is the one. That sends electricity directly to the positive battery post.
GuitarDoug78
May 31, 2015 03:42 PM
Psyte
Electrical Systems/Wiring
Jan 23, 2006 01:15 PM
fiatguy
Dec 4, 2004 06:38 PM
boarder
1983 - 2012 Ranger & B-Series
Nov 24, 2004 11:07 AM
7scott
Apr 15, 2004 03:41 PM
