Sponsored by: Auxito
mirror removal
Old Jan 1, 2012 | 05:59 PM
00GT's Avatar
00GT
mirror removal
03 F150. My driver side mirror glass is cracked so I bought just the glass off eBay. I don't want to remove the whole mirror, I just want to remove the front cover so i can get to the guts to remove the glass backer plate and bring it in the house to adhere the new glass....its cold here...so i don't think the glue will set up right.
Is there any tricks on removing the front cover without breaking it?
Old Jan 1, 2012 | 06:06 PM
phil6608's Avatar
phil6608
Power mirrors or standard?
Old Jan 1, 2012 | 08:58 PM
00GT's Avatar
00GT
Power mirrors
Old Jan 1, 2012 | 09:20 PM
fordf150farmer's Avatar
fordf150farmer
There are two pins which are threaded and go into the motors and provide the angle and up and down. then there is a ball socket right in the middle. Basically just pull firmly and it should pop out. To put it back together insert the pins, get the socket lined up and pop it firmly with your palm while holding the back of the housing with your other hand and it should go back together.
unless they changed the design from the 97. I know i pulled one from a lincoln and it was completely different.
Old Jan 1, 2012 | 11:01 PM
00GT's Avatar
00GT
So i don't have to remove the front cover to pull the mirror then?
Old Jan 1, 2012 | 11:28 PM
fordf150farmer
Nope, just the plastic piece that is the mirror itself. The cap and everything else stays in place.
Old Jan 2, 2012 | 01:01 AM
phil6608's Avatar
phil6608
He is correct.
I replaced mine with turn signal mirrors but it's a PITA!
I took off the hole mirror from the truck to work on it and used a flat pry-bar to pop the old one out. Kinda scary..lol
Here's the how to from the place I bought them from.
http://www.muthco.com/epapers/21000013.pdf
After you get it out,you''ll be able to take it in and glue your new glass on the base.
Old Jan 2, 2012 | 09:01 AM
00GT's Avatar
00GT
Thanks! I'm going to give it a shot this morning....if it breaks I'm blaming you two.....LOL..
Old Jan 2, 2012 | 09:30 AM
phil6608's Avatar
phil6608
lol, Better ware safety glasses and a good pare of gloves!
Old Jan 2, 2012 | 07:15 PM
00GT's Avatar
00GT
Ok I got the mirror off and this is what it looks like. Does it look right?
Old Jan 2, 2012 | 10:40 PM
fordf150farmer
Yup looks good! putting it back will be the tricky bit. Good luck!
Jbrown8988
Jan 2, 2011 12:13 AM
JRM6868
May 9, 2007 09:17 AM
Douglas DC-9
Sep 22, 2005 09:12 AM
KyEdExpedition
Jun 22, 2005 11:30 AM
ghoster55
1983 - 2012 Ranger & B-Series
Jan 22, 2005 02:28 PM
