Hubs
Old Jan 4, 2012 | 11:54 AM
  #31
darren32's Avatar
darren32
Originally Posted by nebmike
Care to elaborate? You saying that mechancially it doesnt function, or just that the locked axle doesnt seem to help you get going any better?
I, for one, am thrilled to have the locking diff. It has unquestionably added a significant degree of capability for the conditions I drive in.
What driving conditions do you use your locking axle in? Since it automatically unlocks at 25 mph I only use it for off road or pulling people out of the ditch etc.
Old Jan 4, 2012 | 12:11 PM
  #32
cummins cowboy's Avatar
cummins cowboy
its surprising how little difference the locking diff makes on most surfaces. I had always thought it would be not as good as 4x4 but something in between. but I am convinced unless one tire is on dry or solid ground the locking diff isn't going to do anything. I do think if you really wanted a locking diff to work it needs to be in the front axle, but to an untrained driver that would open up a whole host of issues.
Old Jan 4, 2012 | 01:32 PM
  #33
nebmike's Avatar
nebmike
Exactly. I spend a LOT of time in the mountains where extreme articulation is common... in those situations a locking diff can make the difference between go or no-go.
I also do a lot of camping in the mountains in the winter/snow with my 35' fifth wheel, and have found the locking diff to be a huge asset there as well.
I would agree that for the skilled four-wheeler, a locker in the front would be 'better' if you had to only have it in one axle.
Old Jan 4, 2012 | 01:53 PM
  #34
darren32's Avatar
darren32
Nothing better than a locker when a wheel is off the ground
Have you bent any sheet metal? I am a bit scared to take this truck too far, to me it doesn't feel all that comfortable flexing too much.
Old Jan 4, 2012 | 03:57 PM
  #35
nebmike's Avatar
nebmike
Actually...
...yes. But not from flexing. I was 'wheelin on Kelly Flats trail in northern Colorado and tried to navigate my rear wheel over a large rock. As soon as I put weight on it, the rock shifted and flipped up against the rear of the step-tube and put two BB-sized nicks in the paint and two corresponding small dents about 3" up from bottom of the sheetmetal in front of the rear tire. And this happened while I still had in-transits on the truck. *sigh*
It actually makes a pretty good trail rig -- at least on trails that arent too narrow.
Since this was a 'hub' thread, I'll just add that when I'm doing trails like that I always manually lock the hubs. Just makes me feel better.
fillerup
Jul 10, 2012 08:47 AM
dqdave1
Aug 5, 2009 01:59 AM
Keepitrunnin
Dec 2, 2007 07:25 PM
BOOTROS
Jun 11, 2005 10:43 PM
Ricks_Red_03
Offroad & 4x4
Apr 8, 2003 07:41 PM
