Hubs
Old Jan 1, 2012 | 04:54 PM
Cable Guy's Avatar
Cable Guy
Hubs
I just traded up from a 2009 6.4 to a 2011 6.7 F250. My old fx-4 had the manual shift in the floor for the 4x4, the new one has the electronic shift on the fly on the dash. My question is...do you still have to lock out the hubs manually with the electronic one or does it do it internally. Logic states you should still have to get out of the truck or do it before driving, but if I don't have to get out in bad weather or a tough spot, I don't want to. Great forum by the way, Ive been on here for hours since I found it.
Old Jan 1, 2012 | 04:57 PM
EpicCowlick's Avatar
EpicCowlick
Welcome to the FTE. No need to manually lock the hubs. They should be turned to the AUTO position on the hub and the truck will engage the hub with placed in 4HI or 4LO. The manual lock is there to allow for full manual engagement if the automatic ever failed for some reason.
Old Jan 1, 2012 | 05:06 PM
Cable Guy's Avatar
Cable Guy
Thanks for the quick reply. Your videos are awesome by-the-way. I really appreciate you taking the time to make them.
Old Jan 1, 2012 | 05:39 PM
wtrlogd's Avatar
wtrlogd
Auto works well, unless you wait till you're already stuck to engage 4x4.
The wheels need to roll a bit to engage the hubs.
Old Jan 1, 2012 | 05:41 PM
EpicCowlick
There you see? Just turn that little **** on the dash and you wouldn't have gotten stuck in the first place!
Old Jan 1, 2012 | 05:47 PM
wtrlogd's Avatar
wtrlogd
I like the ELD button, 3rd gear manual mode, traction control off, large parking lot with 8 inches of snow, round and around we go. fun!
Old Jan 1, 2012 | 07:08 PM
kper05's Avatar
kper05
I still got mine stuck last weekend...lol.
My poor OEM ContiTrac racing slicks that came with the truck that I haven't replaced yet didn't help.
Always have a shovel with you (which I did).
You never know when you'll have to dig yourself out!
Old Jan 1, 2012 | 07:17 PM
bigoltrk's Avatar
bigoltrk
I remember the ContiTracs that came with my 08. I'd get stuck on flat ground with wet grass! Racing slicks is exactly right. and putting it in 4h didn't make it much better either.
Old Jan 1, 2012 | 07:55 PM
jermort's Avatar
jermort
Unhappy super cold, no 4x4
My personal experience with sub 0 temps are negative. My shift on the fly is a 2wd truck when the temp is below 0. Seems like the xfer case is not shifting into 4wd and at least one of the front hubs does not lock up.
Just before Xmas, temp was -8, backed into the street (shifted into 4wd before putting into reverse) promptly got stuck. Rear tires spinning, no front drive!
Dealer could not duplicate the issue last spring, said all was okay.
I have tried leaving in 4wd when parking, but backing up seems to unlock the hubs. Sometimes takes a block or two before the thing actually goes into 4wd. Until then, have to be careful. Don't want to be spinning the rears and suddenly have the fronts lock in!
just saying
jammer
Old Jan 1, 2012 | 08:38 PM
cford716's Avatar
cford716
Just want to make sure I have been understanding this right. I understand the "auto" position. But if you put the hubs in "lock" that just locks the hubs, you still need to actually shift into 4hi or lo to get 4wd. Being locked though prevents you from having to move forward to get into 4wd like when they are in "auto".
Only disadvantage of leaving in "lock" would be slightly lower mpg? Any extra wear and tear?
Old Jan 1, 2012 | 08:49 PM
EpicCowlick
Someone can correct me, but I think the 4wd switching occurs in the transfer case. Which means that if you run the hubs in the locked positon, the front axle and driveline are turning. That would negatively impact mileage and wear. Anyone?
Old Jan 1, 2012 | 08:52 PM
bigoltrk's Avatar
bigoltrk
[QUOTE=EpicCowlick;11226045]Someone can correct me, but I think the 4wd switching occurs in the transfer case. Which means that if you run the hubs in the locked positon, the front axle and driveline are turning. That would negatively impact mileage and wear.
That's the way I've always understood it too.
Old Jan 1, 2012 | 10:28 PM
EpicCowlick
Here's a little more info. Locking the hubs manually engages and turns the axles and the front differential. It does not turn the front drive axle. That happens when the 4wd selector **** is turned and engages the transfer case. We should all manually engage the hubs occasionally to keep the system lubricated. It's been said that a lot of locking hub failures are due to non-use.
Guess what I'm doing tomorrow?
Old Jan 1, 2012 | 10:39 PM
wtrlogd's Avatar
wtrlogd
You sir, are correct.
The wear is mostly on the backside of the ring gear, so not a big deal. On a Jeep Wrangler running with locked hubs (or equivalent) amounted to about 1 mpg, not sure what the mileage effect is on a SuperDuty, as I leave my hubs in auto. Worse case, using auto, is getting muddy/wet to lock in the hubs if you wait too long to shift into 4x4
Old Jan 1, 2012 | 10:47 PM
wtrlogd's Avatar
wtrlogd
Going out to play in the mud?
Actually the forward drive-line will spin with the hubs engaged, but it's dis-connected within the transfer case, so there's no real load on it.
