1978 - 1996 Big Bronco
Temp Cable?
Old Jan 1, 2012 | 02:02 PM
D24x4's Avatar
D24x4
Temp Cable?
First of all, Happy New Year!
I am replacing my heater core - it looks like a fairly easy job. The only problem is I can't get the temp control cable off the core cover. I searched for an answer and found very little.
I know the plastic clip holding the cable is attached to the cover with two tabs on the back. A couple of FTE members said to use a small screwdriver - I tried and couldn't get it off.
Any tips or tricks you guys have would be greatly appreciated.
Thanks,
Mark
94 Bronco
Old Jan 2, 2012 | 10:54 AM
D24x4's Avatar
D24x4
Anybody? I need heat when I go to Colo. next month.
Thanks,
Mark
Old Jan 2, 2012 | 08:53 PM
jimbo285's Avatar
jimbo285
I googled this about a year ago because I was having heat loss. My blend door was not sealing due to my cable being out of adjustment and came up with an article about the cable adjustment. Directly behind the glove-box (removed) on corner of plenum is where i think you are at. If so, there's a clip that holds the cable tight. You can release that clip and remove the cable through it. I got my article from AllData, but I'm sure there are more resources. I'd take a picture of mine except it's -30 out. Sorry.
Old Jan 2, 2012 | 11:32 PM
GruesomeJeans's Avatar
GruesomeJeans
I think he knows what he needs to unclip but he is having trouble unclipping it. I unfortunately cannot help cause i don't know what clips you mean. I have a 78 so i think it is a different setup
Old Jan 7, 2012 | 01:26 PM
D24x4's Avatar
D24x4
Thanks Jimbo & Gruesome! I'll try to release the clip later today or tomorrow.
Mark
Old Jan 7, 2012 | 03:34 PM
jimbo285's Avatar
jimbo285
From what i remember, you just open it enough to slide the ribbed end out through the clamp. Then the wire loop for door hookup should fit right through too. The clamp doesnt "click" open i dont think.
Aynor90
Jan 19, 2015 02:34 PM
MarkCam
Sep 7, 2014 12:42 AM
Twistedwrench
Sep 16, 2012 08:12 PM
FLORESH
Nov 10, 2006 02:29 PM
jimbob21rc
Mar 17, 2005 09:23 PM
