ipr question
Old Jan 1, 2012 | 10:18 AM
4x250cx's Avatar
4x250cx
ipr question
i was changing my icp due to the p2285 code and surging idle and decided to do the ipr valve to,found it on amazon for 162.00 + shipping the old one looks good,screen good clean,figured you got it,put in the new one, went in,but tightens up with the plug straight down. truck is 04 model with Sept.03 engine build,new ipr# cm-5054-3c3z-9c968-aa do i have the wrong part? can the solenoid be rotated? thanks for any response & HAPPY NEW YEAR
Old Jan 1, 2012 | 10:40 AM
bismic's Avatar
bismic
You can rotate the solenoid
Old Jan 1, 2012 | 10:47 AM
4x250cx's Avatar
4x250cx
thanks bismic,any tips on how not to screw it up
Old Jan 1, 2012 | 11:00 AM
1bad04's Avatar
1bad04
I dont know much about these trucks but I do know about this problem all to well! LOL I had mine out one time to check/clean it and when I went to put it back in ever time i tightened it up I could not get the plug back in its original spot facing down. I tried for hours! off/on off/on only to finally find out that once its tight you just grab the dam thing and twist it where you want it.... O-well hope I helped.
Old Jan 1, 2012 | 01:39 PM
4x250cx's Avatar
4x250cx
thanks guys! that did the trick,it was snug,vise and pliers got it where i needed it HAPPY NEW YEAR
Old Jan 1, 2012 | 06:54 PM
BobbyB's Avatar
BobbyB
I bought a nut (axle nut if I remember correct) and screwed it on the old IPR with the o-ring removed. I marked the location of the IPR connector on the nut. Then I screwed the nut on the new IPR and rotated the connector to the marks on the nut. When I installed the IPR, the connector was clocked in the right location.
If you have an IPR socket, you can use it to clock the connector after installing the IPR.
hodges710
Aug 11, 2012 08:35 PM
Big A Towing
28
Apr 26, 2010 06:12 PM
rickatic
Feb 8, 2010 11:27 PM
strokersace
Feb 16, 2009 07:50 PM
TransplantX
Sep 26, 2008 09:20 PM
