Help!! Casting Number ID 351W
Old Jun 18, 2007 | 08:54 PM
baddad457's Avatar
baddad457
Originally Posted by 78ltd
Just because the car line code is "O" does not mean it came
from a Fairlane. That was it's original design application, but
it could have come from a Mustang or Full Size Ford. There is
no way to tell unless you are the one who pulled it out of
the car. Part numbers will tell you what a item was designed
for but many parts were used across the board. Unlike GM,
Ford does not code the car application into the casting.
Ditto on this. You're 110% dead on accurate. As for the 69 Windsor being some how different in it's camshaft retainer plate, I seriously doubt that. Any camshaft and retainer for any 289/302/351W will fit anyother 289/302/351W. They're all the same in that regard.
Old Aug 16, 2007 | 12:36 PM
rgranado1's Avatar
rgranado1
did any 77 Lincoln Versailles ever have a C4 tranny from the factory?
Old Aug 16, 2007 | 12:48 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Welcome to FTE
The answer is no. While the Versailles is basically a Granada/Monarch, some mechanical parts are different. Transmissions were C-6's. Granada/Monarchs used C-4's or FMX's (FMX used on 1975/77 351W engines only). Rear axles were Ford 9 inchers. Granada/Monarchs were Ford 8 inchers. A special crankshaft was used on 1977 models. Ford was trying badge engineering with a twist, but the car never sold well, in fact..it barely sold at all. The problem: It was far more expensive, but looked just like its twin brothers, except for the Continental Mark style decklid.
Another problem: Both Monarchs and Versailles sat side by side in the same Lincoln-Mercury showrooms. The outward appearance was miniscule. Ppl cared less about the special added attractions.
Excepting the C6 transmission, the crankshaft, the decklid and the 9 inch rear axle, the same features (including rear discs) could be had for thousands of $$$ less on Granada/Monarchs.
Old Aug 26, 2008 | 10:06 PM
gary1991's Avatar
gary1991
Question
i have a 351 windsor block with block id number e4ae-6015-fa 4. I have read that it came out of an 84 full size car but i am not sure, can anyone help out? also i want o turn the engine to EFI, i have everything and the know how, but my only question is will i have a problem mating an EFI intake manifold to a head set for carbureation?
Old Jan 28, 2011 | 04:19 PM
dogdays59's Avatar
dogdays59
could anybody please help me figure out what year my motor is . The guy I BOUGH MY 63 F100 PICKUP SAID HE PUT A 351W MOTOR IN IT, BUT I DONT KNOW THE YEAR OF THE MOTOR.here are the #S ON THE BLOCK BUY THE STARTER D4AE-6015-AA-15 7E2? THANKS DOGDAYS 59
Old Jan 29, 2011 | 09:47 PM
Beanscoot's Avatar
Beanscoot
D4AE-6015-AA-15 7E2
The 7E2 is the date code. It indicates that the cylinder block was cast on 7th May, 1977.
Flat 'n Fat
Jul 24, 2022 04:50 PM
dixiestripes351
Mar 30, 2013 03:42 PM
gingerbreadmaniac
Dec 13, 2008 08:27 PM
loudfords
Feb 19, 2004 11:22 AM
Boss_358
Oct 1, 2002 01:38 AM
