intercooler pipe? up pipe?
Old Jan 2, 2012 | 06:42 PM
dukie1877's Avatar
dukie1877
Intake a look at your ipr and icp while the Turbo is off the oil leak could be your icp sensor
Old Jan 2, 2012 | 06:48 PM
freedomfarmer's Avatar
freedomfarmer
Are you talking check for leaks only or also bad sensor? How do I know if they are bad?
Old Jan 2, 2012 | 07:51 PM
dukie1877's Avatar
dukie1877
They both are a pain in the butt to get to when everything is installed. I would pull the IPR which is located on the right side of your hpop cover behind and right of where your turbo is usually. I would pull that sucker and check the condition of it while your there also check for signs of oil comming from the sensor (ICP) behind the IPR If there is signs of oil comming from that sensor or pig tail is covered in oil change the pig tail and sensor. Once everything is back together they are tough to get at.
Old Jan 3, 2012 | 08:51 AM
freedomfarmer
No sign of oil around sensor I traced it to what I think was a leaking oil filter cap or the bottom of housing . Hope that is all it is !
Old Jan 3, 2012 | 09:57 AM
Jimbob8's Avatar
Jimbob8
Originally Posted by freedomfarmer
UPDATE: Everything is out and went better than expected! Turbo wasn't near as bad coming out as some make it sound! Up pipe and y pipe out along with the rest of exhaust ready for banks exhaust to show up wed and rest of parts from tousley on Fri.
Is there any need to try and put the heat shield back on the up pipe and also down pipe ? Not sure if down pipe will come with any on it or not.
Any thing else I should do back there while turbo is out? Sensors etc. Seem to have slight oil leak back there somewhere.
Oh ya AE software also ordered from riffraff !! Be able to read codes once all back together !
Definitely put heat shields, Keep heat off cab. AE gives ya a whole lot more than codes! You'll be impressed. I always expect the worst & enjoy it when it goes easily.
Old Jan 3, 2012 | 11:17 AM
freedomfarmer
Is it a safety concern or just to keep cab little cooler? Old up pipe and y pipe have some shields on then but new up pipe came with out it have to figure out way to reinstall on new one maybe.
Old Jan 3, 2012 | 01:40 PM
Jimbob8's Avatar
Jimbob8
Both, my 94 didn't have any, the steering column would be so hot my feet would sweat. You can cut a U shape about an 1" long x 1/2" wide, bend it down then back flat & hose clamp to pipe.
Old Jan 3, 2012 | 11:18 PM
dukie1877's Avatar
dukie1877
I used header wrap on my down pipe and shields on the rest.
hturner12
Aug 31, 2015 08:51 PM
Amelio
6.7L Power Stroke Diesel
Apr 20, 2015 11:06 AM
Aune163rd
Apr 19, 2011 08:04 AM
idahodisco
Sep 1, 2010 07:03 PM
trencherman
Oct 4, 2008 12:29 PM
