Looking for a rough Estimate...
Old Dec 31, 2011 | 02:23 PM
43snowcone's Avatar
43snowcone
Got a '92 250 7.3 IDI.. acording a Diesel Mechanic i brought the truck to says i have a bad Exhause valve and that it is a Waist of time to Find out wich Cylender it it.to fix the problem.. im looking to get 2 remaned heads and Valves. what am i looking at Price wise to buy and get how many man hours would it be and is it worth it??? i was also thinking of putting a 5 speed into it.. whats is a price for a trans and how many Man hours to do that?
Old Dec 31, 2011 | 04:52 PM
91dirtydiesel's Avatar
91dirtydiesel
Labor on just head gasket alone can be 1500-2000 and another couple hundred in parts....if you went new heads you could probably tack on another 500-1000. The tranny you could probably find for 500, but you pretty much need a donor truck to make the swap smooth, which could take a couple days to complete. That's the way I see it, others can correct me if my numbers are off
Old Dec 31, 2011 | 05:08 PM
hairyboxnoogle's Avatar
hairyboxnoogle
Sounds about right. Or you could perform a compression test and pull that head to drop in an exhaust valve.
Old Dec 31, 2011 | 06:06 PM
84-6.9L's Avatar
84-6.9L
Yep at $1500-2000 labor I'd sure think a 20min compression test is worth the effort, sounds like he needs money in a bad way.
Old Dec 31, 2011 | 06:14 PM
kenpobuck's Avatar
kenpobuck
I bought 2 rebuilt heads from clearwater cyclinder heads for about $350 apiece plus shipping. Then the gasket set and valley pan set for around another $180 so about $900 in parts. I did all the work my self so no labor.
To do the trans swap a donor is defently best. This gives you the small parts that could add up fast. I swapped mine over from c6 to t18 myself so again no labor price and I found the trans (along with the body I swapped) for $800. One of the reasons the labor is so high is the fact that a mech that knows anything about these old rigs knows enough to pull the entire engine. Those heads are heavy akward so the time to pull it is well worth the effort.
Old Jan 1, 2012 | 01:14 PM
43snowcone's Avatar
43snowcone
thanks for the info guys but where can i find the Compression Gauges for my year trick. i cant find one any where.
Old Jan 1, 2012 | 10:29 PM
kenpobuck's Avatar
kenpobuck
I think alot of the guys on here have made there own adapters for the different gauges useing either an old glow plug or injector.
Old Jan 2, 2012 | 07:22 AM
tjc transport's Avatar
tjc transport
i ain't rite
you can get a diesel compression tester from harbor freight.
everyone sells them.
it sounds like you need to find a new mechanic that cares about customers and not lining his pocket with money from unneeded work.
BroncoBilt
1978 - 1996 Big Bronco
Jan 6, 2015 03:48 AM
01f5504x4
Aug 4, 2013 12:29 PM
jeremiah302
Feb 29, 2008 02:29 PM
mlevario99
24
Jul 16, 2007 11:54 PM
95 F250 stump jumper
Dec 23, 2006 02:13 PM
