I don't have experience with both, but I always order the HD or 4600 series (I think that's the number?). They are much less expensive and I have had them on the last two trucks. I like them just fine, especially when you can spend less than $200 and get all 4.
Thanks for the response. I had the HD's on my last truck and loved them. I'm just trying to figure out if the extra $30 or so per shock is a good upgrade or if I'm basically just paying for the zinc-plated finish.
I've had both on my F350 and I couldn't tell you the difference(ride wise) between them. If you live in a salt region, I'd opt for the 5100's as they seem to be holding up much better to that crap.
From what I can determine, the difference is that the 4600 shocks are for "stock" height vehicles but the 5100 shocks are for "lifted" vehicles and has the zinc finish. The internals appear to be the same.
Yup....I went through this. Basically the same shock except the finish and the fact that the 5100 front's allow for 0-2 inches of lift.
Where have you found all four for under $200? I need to buy a set and cheapest I've found a set for is $274.92 at AJUSA.com.
Thanks
