Another trans. Temp question
Old Dec 31, 2011 | 12:48 PM
Billyclub's Avatar
Billyclub
Thanks everyone for the information. Sounds like nothing is wrong, I'm just expecting it to run cooler than expected. I will look into the newer radiator and possibly delete the bypass. I will most likely delete the bypass first and see what happens. Im n the fence about about keeping the truck, been thinking of going to a F150 in the Spring. I love this truck just would like somethng newer
Old Dec 31, 2011 | 01:15 PM
Bonanza35's Avatar
Bonanza35
[quote=Billyclub;11219731]
Originally Posted by mueckster
Are you saying that you only have the ONE Oil-to-Air trans cooler (TruCool) mounted IN FRONT of the radiator and no other coolers? That would explain the higher temps.
Yes only one cooler. The Tru-Cool
Guys that I talked to run the stock cooler and then the Tru-Cool cooler. That way the total cooling space is increased. That is why your temps are high but normal. I would do both, Radiator and reinstall the stock cooler in line also. You will see around 130 degree now and about 180 in the summer months towing. Good luck, Chet
geek guy
Jun 6, 2014 08:02 AM
kenpobuck
35
Mar 21, 2009 09:58 PM
85camaroman
Dec 22, 2008 09:12 AM
Old93junk
Dec 1, 2008 05:58 PM
watermanh
Oct 15, 2005 08:39 PM
