Compression test gauge
Old Jan 2, 2012 | 10:12 AM
RÖENTGEEP's Avatar
RÖENTGEEP
FOREIGN GURU
Smile
Originally Posted by tshrager
Thanks Jose, PM sent
e-mail sent.
Old Jan 2, 2012 | 10:26 AM
stever88's Avatar
stever88
Thank you Sur - PM sent - Steve
Old Jan 2, 2012 | 11:14 AM
RÖENTGEEP's Avatar
RÖENTGEEP
FOREIGN GURU
Talking
Steve,
e-mail sent.
Old Jan 2, 2012 | 11:29 AM
91 Dually's Avatar
91 Dually
IDI uses glow plug a couple inches shorter than Powerstroke. but hole size and thread are the same. I know this from experience. When I changed my glowplugs in my 97 Powerstroke, I found one glowplug from an IDI in one cylinder. Turns out the previous owner broke off that one in the head and just screwed the shorter IDI plug in it's place, leaving the broken tip in the head. Caused me a major headache..
Old Jan 11, 2012 | 03:09 PM
creator's Avatar
creator
I bought one of these kits off ebay "General" brand I believe that comes from harbor Frieght. They have a right angle quick connect fitting which will not reach the adapter down in the head.
After looking around I had decided to either get the $160 Mityvac digital kit, or go cheap and just find another kit with a straight fitting instead of an angle fitting. This is what I just ordered:
12 Pc Engine Compression Tester Kit Direct / Indirect Diesel Engines Test Tuner | eBay
It comes with an angle adapter, but the hose has a straight fitting.
The only other concern is rocker arm clearance on some of the holes as I gather from this forum post:
Homemade Compression Adapter - PowerStrokeNation : Ford Powerstroke Diesel Forum
Sorry about linking another forum but I don't think info is repeated here.
This guy tells you how to make a homemade adapter with a hose connection which would end up being a lot shorter when actually connected as opposed to the length of the supplied adapter and a quick connect. Hopefully I don't have a clearance problem.
I figure if I got my socket extension down in there to replace plugs, I should be able to squeeze the straight quick connect fitting down in there.
Old Feb 5, 2012 | 07:32 PM
creator's Avatar
creator
DON'T BUY THE ONE I LINKED ABOVE!!!! It doesn't even have the schrader valve that holds the pressure in (like every other compression tester I've ever seen. Not like it was even missing, it was not designed with one. The ebay seller gave me a full refund instantly, but was a complete waste of time
I ended up making an adapter using:
- a M10x1mm to 1/8" gauge adapter that came in a kit with other such adapters I may be able to use in the future.
eBay - New & used electronics, cars, apparel, collectibles, sporting goods & more at low prices
-a 1/8" grease gun whip
-A 3/8" female compression to 1/2" MPT faucet adapter (this coverted the hose connection on my normal gas/motorcycle engine hose to NPT)
- 1/2" FPT to 1/8" FPT.
Kind of clunky, but in the end I now have the parts to to a compression test on just about anything.
I would recommend just getting the mity-vac adapter for our engines at $16 it saves the BS I went through.
man-o-war
19
Mar 12, 2021 10:36 AM
bulla
56
May 13, 2016 08:34 AM
cowmilker08
Indiana Chapter
May 2, 2013 09:42 PM
93F250HD
May 16, 2010 07:33 PM
MONAVIERONJON
Apr 19, 2010 07:11 AM
