Compression test gauge
Old Dec 30, 2011 | 11:16 AM
dougbrown's Avatar
dougbrown
Where is the best place to get a compression test gauge. I know snap on sells one but not looking to pay that much. So where to get one?
Also what should a psd have for compression on a 96 with 153,000?
Old Dec 30, 2011 | 11:22 AM
Gobstopper909's Avatar
Gobstopper909
My brother got his from Napa but with the adapter for the glow plug I think it was close to 200 bucks...probly a lot cheaper than snap on...
with the compression, I have read 400 is a brand new engine and any where from 325 to 375 is normal. When I did a test on my green truck with 225k miles it ranged from 365 to 375
Old Dec 30, 2011 | 11:51 AM
dougbrown's Avatar
dougbrown
Any chance I could barrow it?
Old Dec 30, 2011 | 05:16 PM
fordpride's Avatar
fordpride
Harbor fright $30.00 this is the one I have. When I did mine the were all around 365
12 Piece Diesel Engine Compression Tester
Old Dec 30, 2011 | 07:56 PM
tshrager's Avatar
tshrager
Mike, I'm assuming this came with the powerstroke glow plug adapter?
Old Dec 30, 2011 | 08:13 PM
fordpride's Avatar
fordpride
No now that you say that I ordered on from napa it say for ford but the ford adapter that comes with it must be for the IDI it wouldn't fit rite
Old Dec 30, 2011 | 08:20 PM
RÖENTGEEP's Avatar
RÖENTGEEP
FOREIGN GURU
Lightbulb
I have that but I think it has every adapter, but for PSD . IDK for sure because I havent used yet, but I have read what I mentioned.
You can buy this
Mityvac , MVA5605 Diesel Glow Plug Adapter - Ford Navistar 7.3L Power Stroke
EDIT: I have this info saved with that adapter from other forum:
this does not fit the HF quick connect fitting so i took it to a logging store and looked through the hydraulic fittings and found a quick coupler that had female threads on one end and the other, female quick connect ($6.00). it snapped over the adapter. in the HF kit there is a fitting with a compression nipple on one end and male threads on the other. i screwed the HF nipple onto the hydraulic fitting and that worked as a coupler between my GP adapter and HF compression tester.
Old Dec 30, 2011 | 08:38 PM
tshrager's Avatar
tshrager
You can buy this
Thanks guys. For 30 bucks I'm going to get it, but now I'll have to make it work properly with our trucks
Old Dec 30, 2011 | 08:47 PM
RÖENTGEEP's Avatar
RÖENTGEEP
FOREIGN GURU
Wink
If you PM your e-mail I can send you a file with more info about the HF kit and other alternative for a home made adapter (but maybe this could not be this year, but next year as soon I got this PC, OK?)
Old Dec 30, 2011 | 09:47 PM
tshrager's Avatar
tshrager
Thanks Jose, PM sent
Old Dec 31, 2011 | 05:14 PM
Gobstopper909
Ill ask him and let you know Doug
Old Dec 31, 2011 | 06:32 PM
axel 56's Avatar
axel 56
are the glow plugs different on the 7.3 power stroke than the IDI
Old Dec 31, 2011 | 07:41 PM
dougbrown's Avatar
dougbrown
I think they are.
Old Jan 2, 2012 | 10:06 AM
stever88's Avatar
stever88
Jose - Can I PM you my e-mail so I could also receive the the info on the Comp tester as well - Thanks, Steve
Old Jan 2, 2012 | 10:11 AM
RÖENTGEEP's Avatar
RÖENTGEEP
FOREIGN GURU
Red face
YES SIR, anytime. I have it in a Doc document, and I dont know how to convert it to GIF, JPG or whatever to upload here directly.
Ill wait your e-mail for sure.
