Compression test results, How bad is it?
Old May 16, 2010 | 04:29 PM
93F250HD's Avatar
93F250HD
Ok, trying to diagnose power probems, did a dry compression test and this is what I got
138
135
135
135
135
145
140
127
This was done with a pretty cheap gauge, but still its pretty consistent.
Old May 16, 2010 | 04:35 PM
quicklook2's Avatar
quicklook2
looks ok to me.
not the best, but no 0 compression.
zxwut?'s Avatar
zxwut?
Looks lowish. 170-180 would be nice.
On the plus side, they are fairly consistent.
Old May 16, 2010 | 04:37 PM
93F250HD's Avatar
93F250HD
Forgot to mention 5.8L 351, I didnt do a wet test because they were so consistent I wanted to see how low they were first.
Old May 16, 2010 | 04:56 PM
Ricky B's Avatar
Ricky B
I agree, not too bad. But do we know how many miles are on his engine?......
lew52's Avatar
lew52
How many miles on the motor ?? Let us know what the wet test shows ....Lew
Old May 16, 2010 | 04:59 PM
93F250HD's Avatar
93F250HD
93k miles, is a wet test really necessary since they are so close anyway, I thought it was just used to try to diagnose if one was off.
Old May 16, 2010 | 05:00 PM
quicklook2's Avatar
quicklook2
your gauge may be off.
Old May 16, 2010 | 05:10 PM
lew52's Avatar
lew52
The wet test will tell you if the rings are bad , or something else...
Old May 16, 2010 | 05:27 PM
Ricky B's Avatar
Ricky B
Hmmmm, now those numbers look a bit low to me, as I'd be guessing that 8 cylinders in the mid 150's---> low160's would be a bit better.
Did you do this test with the engine warm?........
Old May 16, 2010 | 05:47 PM
danr1's Avatar
danr1
Was the motor up to running temp for testing? did you remove all the spark plugs and hold the throttle full open during cranking, and using a strong battery?
Allowing each cylinder 3 compression strokes to build full pressure?
Did the pressure rise quickly in each one? Reaching the max number for the given cylinder in those 3 hits?
Your numbers you got might be a little low if you didn't do one or all of the above while testing, say you only took out one plug at a time or didn't hold the throttle open or both, but even at that your numbers are fine.
The wear is even, that being the important thing.
No need to wet test, your numbers do not suggest a problem where you'd want or need to go further with testing.
Old May 16, 2010 | 06:18 PM
93F250HD's Avatar
93F250HD
Thanks for the replies, I think this Im in the clear and can go on to the next thing. The engine was warm, but had cooled a little while I went about setting up for the test, Def below normal operating.
oh and..
It rose to 95 on the first jump, then 120 then the final number
also had a battery charger connected.
Old May 16, 2010 | 06:50 PM
quicklook2's Avatar
quicklook2
i would get a reliable gauge and check it again.
Old May 16, 2010 | 07:07 PM
lew52's Avatar
lew52
Yeah make sure you have a good Gauge , you don't have to do a wet test , thats just going to tell you where the ware is , top or bottom , 93k isnt much for a 93 , original motor ?? ...
Old May 16, 2010 | 07:33 PM
93F250HD's Avatar
93F250HD
Yep, all original no real rust, clean interior. I love the truck I just want to get it to where I have faith in driving it anywhere. The biggest problems I have had with it is because it has sat so much alot of seals dried out. So I have replaced many gaskets
SKaero
Aerostar
Aug 16, 2016 11:59 AM
animator
Sep 2, 2015 01:37 PM
MikeS29
Jun 10, 2011 09:02 AM
khardrunner14
Feb 22, 2010 12:53 PM
