front end lowering
Old Dec 30, 2011 | 09:48 AM
zombiefied 247's Avatar
zombiefied 247
front end lowering
i just took a few leafs out of the front end of my 55 f100 what is the best way to shorten the bolt that goes thru the springs so i can get everything buttoned up again in the front. i figure i can grind a bit out of the bump stop that the you bolts hold down so it will fit over it again like it should. all help is apreciated thanks all
Old Dec 30, 2011 | 10:32 AM
GreatNorthWoods's Avatar
GreatNorthWoods
I wouldn't bother with shortening the bolt. I've just used a shorter grade 8 bolt for such applications. You can easily round off the bolt head on a grinder....
Old Dec 30, 2011 | 07:58 PM
zombiefied 247
i didn't even think of that. thank you
Old Dec 30, 2011 | 10:53 PM
BigPigDaddy's Avatar
BigPigDaddy
I just replaced mine with the grade 8's and rounded the heads off on the grinder. Worked great for me.
Old Dec 31, 2011 | 03:03 PM
needhelp49's Avatar
needhelp49
a year ago i wouldn't of said this but be careful removing leafs i did it that way and now i have a truck sitting on the bump stops
Old Dec 31, 2011 | 03:42 PM
zombiefied 247
thanks for the advice i will definatly becareful
onuredneck707
Oct 10, 2019 06:09 PM
HelenT
Oct 1, 2018 12:19 PM
xtremexj
Aug 12, 2013 03:55 PM
Farmboypowerstroke
Feb 8, 2009 07:04 PM
six7seta
Dec 18, 2004 07:50 PM
