ahh crap
Old Feb 8, 2009 | 06:07 PM
Farmboypowerstroke's Avatar
Farmboypowerstroke
ahh crap
I twisted a bolt off, its the one that holds the tranny to the cross member. There are 2 bolts, now there is only one. How do i replace the bolt? Or will I be ok with one?
Old Feb 8, 2009 | 06:15 PM
new2diesel's Avatar
new2diesel
I would'nt run it for long that way. Hopefully you can easy-out it, maybe soak er down good and heat. Probably end up being $15 bolt from Ford. Good luck!
Old Feb 8, 2009 | 06:19 PM
Bigcat350's Avatar
Bigcat350
Wow FB I would want to replace it it was me. I would get a good EASY OUT and drill a hole in the bolt, then heat it up with a torch a little and and then try to get it out. I hate it when this happens but it does.
Old Feb 8, 2009 | 06:28 PM
Farmboypowerstroke
ok i'll have to replace it, but has anyone did this? You can't see the bolt head, where is it?
Old Feb 8, 2009 | 06:40 PM
new2diesel's Avatar
new2diesel
If you broke the bolt off, there won't be a head visible. Usually there is a mounting block
bolted to the trans and to the crossmember. If you,re lucky you just broke the bolt in the
trans mount block. It will have rubber sandwiched between steel plates (for vibration). If
thats the case, remove the block from the trans and you can work on it off the truck.
Old Feb 8, 2009 | 06:42 PM
new2diesel's Avatar
new2diesel
You'll have to take the weight off the crossmember with a jack.
Old Feb 8, 2009 | 07:04 PM
PowerstrokeJunkie's Avatar
PowerstrokeJunkie
Jack up the transfercase, remove the cross member, and you can unbolt that whole vibration isolator from the tailshaft section and get a new one.
fridgeddiesel
26
Sep 10, 2024 08:52 AM
Bigfwt04
Jul 12, 2009 01:22 AM
mds01
1978 - 1996 Big Bronco
Aug 4, 2005 01:20 PM
Cheshire Cat
1966 - 1977 Early Broncos
Mar 23, 2004 06:48 PM
