axle swap
Old Dec 31, 2011 | 07:32 PM
f1501987's Avatar
f1501987
Another question, I currently have 3,55 gears. Will 4.10s make a big difference. And my truck is lifted. Will the axle still work
Old Dec 31, 2011 | 07:50 PM
dougbrown's Avatar
dougbrown
4:10 would make it better to drive and get up to speed. It will how ever make highway speeds be tacked up there. Mine 2,000 for about 63 mph.
Old Dec 31, 2011 | 08:00 PM
f1501987's Avatar
f1501987
Since my truck is lifted will everything still work
Old Dec 31, 2011 | 10:27 PM
Brown Falcon's Avatar
Brown Falcon
Yes, the axles will still work if it's lifted. 4.10 gears will be better for taller tires, just make sure you have matching gears front and rear.
Old Jan 2, 2012 | 06:01 PM
f1501987's Avatar
f1501987
well I bought them for 750. front axle, rear axle, leafs on rear, rotors and drums, But I have a quick question how hard is it to take the 4:10 gears out of the front d-60 and if I can, can I put the 3:55 gears out of the d-50 into the d-60? I dont really want to get 4:10s. Ill have the front axles out tommaro.
Old Jan 2, 2012 | 06:03 PM
f1501987's Avatar
f1501987
And what all has to come out. ring. pinon? or what to change over gears
Old Jan 2, 2012 | 06:24 PM
dougbrown's Avatar
dougbrown
I think they are different. And to Rome the ring and pinion you have to;
1. Drain diff, and romove cover
2. Remove hubs
3. Remove knuckles
4. Remove axles
5. Remove 4 bolt holding ring gear and housing in diff. 2 each side.
6. Remove bolts that hold ring gear to housing.
7. Remove bolt that holds yoke on and remove. May need puller
8. Pinion gear should now come out.
It goes back together the same way. Everything must be shimmed and set to ford specs. If not it will implode on it self.
tjc transport's Avatar
tjc transport
i ain't rite
nope. D-50 gears are different than D-60 gears and will not swap.
Old Jan 2, 2012 | 06:31 PM
dougbrown's Avatar
dougbrown
Thanks Tom, that what I was figuring but not 100% sure.
Old Jan 2, 2012 | 06:59 PM
f1501987's Avatar
f1501987
Damn, So Ill have to swap my rear gears out
Old Jan 2, 2012 | 07:07 PM
dougbrown's Avatar
dougbrown
That how it looks.
Old Jan 2, 2012 | 07:08 PM
f1501987's Avatar
f1501987
Would it be easier to change the gears out or the whole axle.
Old Jan 2, 2012 | 07:15 PM
  #28
dougbrown's Avatar
dougbrown
Whole axle! There not that hard.
Old Jan 2, 2012 | 07:27 PM
  #29
f1501987's Avatar
f1501987
So your saying its easier to change a 400lb+ peice than taking the rear end apart.I'm just asking to not trying to be smart or anything, b/c id rather keep my 3:55 gears.
Old Jan 2, 2012 | 07:35 PM
  #30
dougbrown's Avatar
dougbrown
Can u shim gear? Do u have the tools? Most people can't.
Your are going to pay 500 to 600 for a new 3.55 ring and pinion set. So to me it be easier to change rears. I could do the rear in about 2 hours. Not really that hard. The front I never removed a Dana 50 and installed a 60 but will be in a short time. Im sure that only be a few hours too.
