Shock question when installing v codes
Old Dec 29, 2011 | 10:02 AM
labman1014's Avatar
labman1014
My v codes came in today but have a question on shocks. Will the original shock work or will I need some that fit a f250? Mine r less than 6 months old and would hate to replace them.
Old Dec 29, 2011 | 11:56 AM
dave91gt's Avatar
dave91gt
Shocks work fine. Used them on my 03 V10 when I went with V's. Even used the stock ones on my 01 with X codes.
Old Dec 29, 2011 | 02:43 PM
robert_l_ross's Avatar
robert_l_ross
When you put in the 3.5" rear blocks...what do you have to do with the rear shocks...do they need replaced to accommodate the height difference?
Old Dec 29, 2011 | 03:39 PM
Stewart_H's Avatar
Stewart_H
Nothing, no.
The OEM and Bilstein OEM replacement shocks have plenty of travel.
The fronts are serviceable too, but Bilstein recommends the F250 OEM replacement Bilstein because that one has a little more travel than the Excursion version.
Stewart
Old Dec 29, 2011 | 08:21 PM
white Buffalo's Avatar
white Buffalo
When it comes time get the Bilsteins, they really are much better than stock. Have had them on my F-250 for about 6 years and on the Excursion for a year along with the modded B codes and V codes. The stock shocks will work for now.
Old Dec 29, 2011 | 08:28 PM
robert_l_ross
Originally Posted by white Buffalo
...modded B codes...
? What mod...RAS or something different?
Old Dec 29, 2011 | 08:41 PM
white Buffalo
Robert,
The B code Spring Mod:
Take the two shortest leaves from the Excursion stock spring packs and add them to the B code spring packs between the shortest leaf and the bottom overload leaf.
Here is a link to some pics when I upgraded my suspension. I take no credit for this - Cary (CT Performance) set me up with exactly what I needed.
https://www.ford-trucks.com/forums/1...ff-diesel.html
Old Dec 29, 2011 | 09:15 PM
dave91gt's Avatar
dave91gt
factory rear shocks are plenty long enough for the F350 blocks.
Big-1
Jul 28, 2019 08:50 PM
Jkelley
Aug 27, 2017 07:57 PM
ithaca1230
Jun 20, 2013 07:06 AM
paraskr
Feb 5, 2013 05:05 PM
FireHawk4
Oct 8, 2012 11:38 PM
