Suggestions on Replacing the Shocks
Old Aug 17, 2017 | 06:28 PM
Jkelley's Avatar
Jkelley
Hey Guys I need to replace the Shocks on the BEAST she has a little over 222k on them ...Momma has put me on a Budget since getting back from Orlando...Please Hit me with your Suggestions..What Shocks you like and which ones to Stay away from...Thanks!
Old Aug 17, 2017 | 11:26 PM
Simps's Avatar
Simps
Only buy bilsteins. I bought Monroes. Worthless after 6 months.
Old Aug 18, 2017 | 07:16 AM
sddesigns's Avatar
sddesigns
FTE Leadership Emeritus
FTE Emeritus
Ditto on Bilsteins
Here is mine with V Codes in the front and F350 Block Rear and RAS setup.
Bilstein OE Steering Stabilizer - 24-158848
Bilstein 5100 Shocks – (Front 33-187297 - Rear 33-151656)
Old Aug 18, 2017 | 08:58 AM
Blakshukvw's Avatar
Blakshukvw
My first preference would be bilsteins but the Rancho 9k series are pretty good but they're about the same price as the bilsteins so...
Old Aug 18, 2017 | 09:26 AM
andym's Avatar
andym
I've only run Bilstein 5100s on mine, but I like them very much.
Old Aug 18, 2017 | 10:29 AM
unleashd's Avatar
unleashd
Originally Posted by sddesigns
Ditto on Bilsteins
Are these the same for the 2000 7.3L Diesel? I need to get new shocks too. My truck is stock height.
Thanks to the OP for bringing this up as I was going to start a thread too
Old Aug 18, 2017 | 10:33 AM
sddesigns's Avatar
sddesigns
FTE Emeritus
Those numbers will fit with 0-2.5" front lift and 3"-5" Rear above stock.
Looks like it will fit 2000 7.3 also.
Rear
Part Number: 33-236964
Old Part Number: 33-151656
Front
Part Number: 33-187297
Old Part Number: BE5-F580
Old Part Number: F4-BE5-F580-H0
Old Aug 18, 2017 | 10:42 AM
unleashd's Avatar
unleashd
Those numbers will fit with 0-2" front lift and 2"-4" Rear above stock.
Ahh....OK. Back to my search for stock height shocks
Old Aug 18, 2017 | 11:48 AM
RobRoss's Avatar
RobRoss
Where are you located?
Old Aug 18, 2017 | 11:59 AM
brian42's Avatar
brian42
Veteran: Navy
I thought about Bilstein (their world headquarters is 10 minutes from my house) but ended up going with Rancho RS9000XL. They were having a sale (4th one free) so I gave them a shot. I am glad I did as I love them. Plus I like the adjustability so I can adjust them for street, towing, and off-roading. Just my .02
Old Aug 18, 2017 | 12:13 PM
RobRoss's Avatar
RobRoss
I used the adjustable Ranchos in the rear of my truck. I took the adjuster **** off and packed the piston cavity with moly lube to prevent the piston from seizing. My first set did and Rancho did replace them under warranty but it's nice to have the adjust-ability when you need it.
Old Aug 18, 2017 | 12:45 PM
Rancho Suspension's Avatar
Rancho Suspension
Former Vendor
Promotions
Rebate info!!
And that was a long life on the shocks too!!
Old Aug 18, 2017 | 01:02 PM
brian42's Avatar
brian42
Veteran: Navy
Good to know. I'll keep an eye on mine. 91K miles so far and they're still working well.
Old Aug 18, 2017 | 02:54 PM
03X's Avatar
03X
I put in Skyjacker M95s and their 9000HD stabilizer and WOW what a difference. Not harsh on the pavement either.
Went through 2 sets of the Monroe Reflex in 2 years.... did not last for me. both times shocks were severely leaked out...and I do not off road either. Rough gravel roads 30% of the time though.
Old Aug 18, 2017 | 06:32 PM
Nicmike's Avatar
Nicmike
Veteran/Sheepdog
I bought the Monroe shocks once....never again. Bilstein or Rancho FTW.
