Modular V10 (6.8l)
code p0451, check engine light?
Old Dec 29, 2011 | 09:36 AM
redbull660's Avatar
redbull660
On my 2008 f350 with a v10 just had the check engine light come on. I hooked my scanner up to it and it give me a code p0451. I am just about to go on a trip today. Is it ok to drive it like this, what does this code mean. Thanks.
Old Dec 29, 2011 | 10:18 AM
Bbasso's Avatar
Bbasso
used google and put in P0451
Code P0451 evap emission control system
Old Dec 29, 2011 | 10:54 AM
jh818's Avatar
jh818
It's ok to drive. It just means that your fuel tank/cannister can't hold a vacuum when it tests for it. Or, not sensing a vacuum. That's how the computer detects if there is a leak in your fuel system. Could be as simple as a bad gasket in your gas cap.
It's almost like driving with your gas cap off. That light is annoying, though.
Old Dec 29, 2011 | 02:13 PM
MDSuperDuty's Avatar
MDSuperDuty
That happened to me and guess what.....my gas cap wasnt screwed on tight! That's all it was for me. Check that.
Old Dec 29, 2011 | 03:59 PM
redbull660's Avatar
redbull660
yep,it was a loose gas cap. Thanks guys.
Old Nov 26, 2012 | 12:22 PM
pascot3's Avatar
pascot3
p0451 code
Last year at emissions inspection I was told to get a new gas cap. I did, however, my check engine light came on. I had two mechanics check on the code and they said not to worry about it. Well, this year I failed the emissions test and went to another mechanic. He said I needed a Ford factory gas cap, which I purchased and put on. He reset the codes to ready and within a few hours the light was back on. Now the mechanic wants to drop (?) the gas tank to look for leaks. I am starting to get into real money on a 2004 suv with 128,800 miles on it. I called Emissions Control as directed on their website to see if there is a waiver or alternative and left two messages no return calls yet. My tags expire in 4 days. Any ideas?
Thanks,
Old Nov 26, 2012 | 08:03 PM
jh818's Avatar
jh818
Check the hoses near your charcoal canister for leaks or cracks. That is where I would start.
beerguy5812
Jun 2, 2009 12:59 PM
lovs2fly
Oct 4, 2006 10:49 PM
misspolly1969
Sep 28, 2004 09:27 AM
330design
1997 - 2003 F150
Jun 28, 2004 09:56 PM
Dilliw
Apr 5, 2004 02:30 PM
