Mirror 'left' switch?
Old Dec 29, 2011 | 02:10 AM
Thudpucker's Avatar
Thudpucker
On my 97 F150/Lariat/4X4/5.4/Auto....
My Door Mirror switches "Raise, Lower and side to the left all work good. But the Move to the right don't work.
I'd remove and check those switches to start with.
How do I get the Switch panel out of the door without wrecking things?
Old Dec 29, 2011 | 08:15 AM
Franklin2's Avatar
Franklin2
It probably just pulls out with a putty knife, but I would take the entire panel off if you are afraid of breaking it.
Old Jan 1, 2012 | 06:10 AM
JWA's Avatar
JWA
If you're not already solved this issue do you have a photo of the control panel mounted on the door? I might be able to suggest a way to remove it without damage.
Franklin's suggestion about the putty knife is good, the only "trick" being where to insert it under the mirror control in order to pop it out damage free.
narrowfarm
Oct 16, 2014 09:22 PM
makthenif
Nov 14, 2011 10:47 PM
Wolverine72
Jun 20, 2007 12:47 PM
ArkansasFordMan
Mar 26, 2004 02:47 PM
2001ExcursionV10
Feb 4, 2003 04:02 PM
