Anti-freeze in smog muffler??
Old 12-28-2011, 04:57 PM
farrell262's Avatar
farrell262
farrell262 is offline
i just recently installed a new thermostat because my heater would only get warm the first two installments had leaked from the housing because of using temperature sensative sealants, well the third time i purchased the correct sealant and re-installed the thermostat and the motor ran smoother and heater got warmer but after driving a while a fair amount of anti-freeze came out but it was not leaking from the thermostat, the only place i could think of it coming out of was the smog muffler because due to a clog somewhere and it purging out but i am not sure.
Old 12-28-2011, 07:17 PM
Edgethis's Avatar
Edgethis
Edgethis is online now
The only way Antifreeze is leaking out of there is if it leaked into there in the first place.
Old 12-28-2011, 08:01 PM
White 97 xlt's Avatar
White 97 xlt
White 97 xlt is offline
In your other thread on the SAME subject, I believe you mentioned over filling after replacing the thermostat, I would venture a guess the antifreeze was sucked in there.
The air/smog pump intake muffler does not have antifreeze going to it.. ONLY air.........
Old 12-29-2011, 02:38 AM
farrell262's Avatar
farrell262
lol yeah in the other thread i also said i was going to start a new thread because it was all messed up, but i wasnt sure because there is, what i believe the pump, that has 3 other hoses similar to my coolant hoses, if i knew what was going on i wouldnt be on here asking questions.
Old 12-29-2011, 06:41 AM
Edgethis's Avatar
Edgethis
Those are air/vacuum lines for the smog system. They have nothing to do with the coolant lines.
d-day
12-18-2014 01:29 PM
pablocruz69
1997-2006 Expedition & Navigator
30
02-11-2010 10:28 AM
Jake331
11-10-2007 08:11 PM
cmosis5
09-01-2007 02:25 AM
JWill
Aerostar
12-07-2004 10:10 PM
Quick Reply: Anti-freeze in smog muffler??
