Aerostar Ford Aerostar
New thermostat?
Old Dec 6, 2004 | 03:48 PM
JWill's Avatar
JWill
New thermostat?
Have a 92 V6 XL and when the van is idle say at a light, the heater blows a luke warm-coolish air but, when actually in motion, the heater works perfect. Is this just a simple case of a malfunctioning thermostat?
Old Dec 6, 2004 | 06:34 PM
tom_foreman's Avatar
tom_foreman
That sounds more like the water pump. The pump is not pushing much coolant when the engine is running that slow. The coolant in the heater core cools off. Rev the engine and more hot coolant flows through the core and you get more heat. That's my guess.
Old Dec 6, 2004 | 08:15 PM
JWill's Avatar
JWill
You're absolutely right. So it looks like I need a new pump eh?!
Old Dec 7, 2004 | 04:50 PM
tonyr's Avatar
tonyr
I would say your system needs a flush and possibly a new heater core-it sounds fouled-especially if the operating temp is where it is supposed to be.
Old Dec 7, 2004 | 09:27 PM
tom_foreman
I like the idea of flushing things out first. It's cheaper and may fix the problem. Someone here suggested flushing the heater core seperate from the rest of the system and to flush it both ways. Good idea.
Then if it still doesn't work check out the pump.
Old Dec 7, 2004 | 10:10 PM
lasher's Avatar
lasher
you can check the water pump by undoing the heater hose by the water outlet of the engine and installing another peice of hose there. start engine. water should shoot out of the hose at idle. if not your pump is bad. keep a water hose in radiator to keep it full when your doing this.
Nov 27, 2012 06:00 PM
kajunkenny
Dec 25, 2010 02:04 AM
jb85302
Dec 12, 2009 05:08 PM
texas4x4
2004 - 2008 F150
Jan 15, 2009 07:51 AM
OzarksFord
Aug 15, 2007 10:32 PM
