headlight beep
Old Dec 28, 2011 | 09:35 AM
leebrown5's Avatar
leebrown5
headlight beep
94 F350, apparently has an alarm to tell you if one of the headlights is burnt. It did this to me last summer, one lamp was dead, I replaced it. Done.
Last night I start up, same alarm, only goes off when the headlights are on, only I can't see any lights out...
any ideas? I checked hi and lo beams, tail lights look ok but I can't check the reverse until I get somebody to help me.
TIA
lee
Old Dec 28, 2011 | 09:36 AM
Edgethis's Avatar
Edgethis
Never heard of such an alarm. Are you sure its not the door alarm?
Old Dec 28, 2011 | 09:45 AM
SideWinder4.9l's Avatar
SideWinder4.9l
TIA
lee
Turn the key ON, and pull the gear selector down to R.....
or put it in reverse, if a manual...
And the lights will come on as normal...and you can walk around and check them....
*Make sure your parking brake is set....
Old Dec 28, 2011 | 10:28 AM
leebrown5's Avatar
leebrown5
thanks guys, my truck is possessed...
didn't do it this morning, so I don't know what to say. it's not the door, because it goes out when the lights are turned off. Last year it only beeped until I swapped out the headlamp, then no more beep, so I 'assumed' that it was a design feature for my truck.
Thanks anyway :-)
Lee
Old Dec 28, 2011 | 10:32 AM
Midnite1987's Avatar
Midnite1987
I'm thinking maybe it's the warning buzzer for when you leave your lights on and turn the key off?
Old Dec 28, 2011 | 10:40 AM
Edgethis's Avatar
Edgethis
Im gonna guess that it may be a bad/ignition cylinder. Maybe sometimes it contacts and sets off the buzzer....just a thought.
Old Dec 28, 2011 | 04:00 PM
leebrown5's Avatar
leebrown5
thanks for the ideas
started it 1/2 dozen times today, no beep. It's apparently possessed, but it runs fine so whatever... I can't check the rear lights cause it's a standard- I need somebody to help me out. No e-brake anyway, another project in the waiting. Not the door, cause the doors were all shut (it was 18 degrees last night :-) and it's not the lights-on/key-out because it was beeping while I was driving, in the dark, and couldn't shut it up!!
I'm thinking perhaps key cylinder. That's really sloppy anyway, sometimes I have to line up the silver turn-ring when you put the key in or the key can get jammed in misaligned and it wont turn. (I just leave the keys in it usually, nobody here wants to steal this beast)
Thanks everybody!! Happy New Year... Lee
Old Dec 28, 2011 | 04:21 PM
Edgethis's Avatar
Edgethis
Sounds like a new key cylinder (~$12) wouldn't hurt and it may even fix your random beeping.
You can still check the reverse lights, just put it in reverse instead of first (or whichever gear you park it in) and turn the turn to acc (not run, just so radio comes on)
Old Dec 28, 2011 | 05:42 PM
leebrown5's Avatar
leebrown5
hey- the acc, reverse thing is good to know!!! THANKS!
the cylinder will have to wait till next spring, it's too durn cold to be playing out there this time of year what with no garage and all...
thanks again!!
lee
Old Dec 29, 2011 | 02:49 AM
SideWinder4.9l
thanks again!!
lee
What is so hard about taking a SMALL screwdriver, pushing the lock pin in, and turning the key a tad and pulling the cylinder out?
Literally a 2 minute job.....
And the replacement cylinder simply slides in, and when you turn the key...The pin pops out, locks the cylinder in place and is DONE...
There is a hole on the bottom of the steering column.....You can't miss it...
Old Dec 29, 2011 | 08:39 AM
leebrown5's Avatar
leebrown5
cylinder replacement
if the truck doesn't beep anymore, it will be spring before I do that :-)
it's 9 degrees out there, and the truck doesn't do heat... but that's another story.
but now that I have the directions, I will add it to the list.
thanks
lee
Old Dec 29, 2011 | 09:19 AM
Edgethis's Avatar
Edgethis
Its super eeasy and quick to swap out the key cylinder as Wes said. Just make sure that you do NOT turn the new cylinder at all until it is installed into the steering column. Little pins will shoot out if you do.
Old Dec 29, 2011 | 09:23 AM
Midnite1987
Sounds like someone figured that out the hard way lol
Old Dec 29, 2011 | 09:27 AM
SideWinder4.9l
Yeap......
Old Dec 29, 2011 | 09:36 AM
Edgethis's Avatar
Edgethis
Yeah Thankfully i was still at the parts store, and quickly decided I didn't want that one.
johnboy74
Oct 10, 2018 08:17 PM
Becky_is_a_66
15
Jun 29, 2013 06:23 PM
geotracker91
Crossovers
May 1, 2013 09:52 PM
j_blueridge
2004 - 2008 F150
Oct 20, 2010 05:06 AM
huskermark764
1997 - 2003 F150
Dec 6, 2008 12:18 PM
