exhaust theory
Old Dec 27, 2011 | 07:00 PM
toe_cutter's Avatar
toe_cutter
exhaust theory
I just got a fuel injected 300 f150, I'm pondering the exhaust options and wanted some input. My current truck is a 93 chevy 350 and have done alot of changing the exhaust to get it the way I want and would like to avoid that this time around on the 300. Most info on exhaust work has to do with v8 and riceburners, so I'm sort of in the dark here. To make the deepest tone on these engines what would be the best route? On my Chevy I have 2.5 pipe to the y, one foot of 3 inch a 3 inch Thrush welded turbo, 6 inches of pipe, then a 3x24 glasspack, no turndown, just dumbs at the front of the bed. When you walk past at idle you can feel it in your innards, its not overly loud at all, and very mild over 2k rpm. I know that the 300 will not sound the same, I just dont want is to sound like a tractor, nothing againt the tractor sound, or people who's trucks sound like tractors, just not for me. Dual 2.25 pipes, no cats, to turbo mufflers or glasspacks and either turndowns or side exit behind the cab? OR, 2.25 duals to y to 2.5 or 3 inch, pack or muffler, side exit or turndown?
Old Dec 28, 2011 | 02:09 AM
SideWinder4.9l's Avatar
SideWinder4.9l
Unless you're going for a ******* child of a broken down Cummins/Farm tractor....leave it be....Put the money elsewhere, because in the end, it'll still sound like a tractor....
Old Dec 28, 2011 | 09:15 AM
big-ugly's Avatar
big-ugly
Great way to put it, Wes. I woulda repped you, but "they" won't let me
This one doesn't sound much like a tractor to me, I hope to get mine to sound about like this one day.
(skip ahead to 1:00 to avoid a bunch of bullsh..).
http://www.youtube.com/watch?v=BZxGQ079D8o
Old Dec 28, 2011 | 09:24 AM
SideWinder4.9l
That sounded pretty good....But let it lug out on the highway, etc...it'll sound like a pissed of John Deere/Ford 9N.....Just saying...
Old Dec 28, 2011 | 09:34 AM
big-ugly's Avatar
big-ugly
You are 100% correct. Might as well get some stacks coming outta the hood with rain caps, it'll sound about the same.
Although he did rev it up a little. My truck idles down the highway at about 1700 rpm in 5th at 60. Seems like I could keep mine in that range and get a nice loud note out of it.
Old Dec 28, 2011 | 09:41 AM
SideWinder4.9l
yup....I'm actually pulling the muffler off mine.....The whine, etc is just too annoying....
Old Dec 28, 2011 | 09:48 AM
big-ugly's Avatar
big-ugly
yup....I'm actually pulling the muffler off mine...Going with a Walker factory muffler.....The whine, etc is just too annoying....
Come on over, if you cut mine out of my truck you can have it
Old Dec 28, 2011 | 10:46 AM
Harte3's Avatar
Harte3
https://www.ford-trucks.com/forums/7...und-clips.html
Go through that "Sticky" found at the top of the Forum page.
Old Dec 28, 2011 | 06:24 PM
toe_cutter's Avatar
toe_cutter
I have been listening to sound clips for the last three days, I suppose I will just fully embrace it, go to TSC and get a muffler with the rain guard flapper and run a single stack. If its gunna sound like a tractor I'm gunna put a tractor muffler on it! I've got to repace the exhaust anyway, its a cheap turbo that rotted and the cats are clogged from a missfire that never got taken care of by the previous owner.
Old Dec 28, 2011 | 06:48 PM
351M's Avatar
351M
Take a look through those tractor mufflers before you buy them. I have seen some with a washer welded in just below the outlet to restrict and shut them up more. (Causes more flow into the louvers)
I'd keep listening to clips and don't rush... Took me awhile to get mine right last year, now I'm starting over because I swapped to the EFI manifolds. That one posted above with the true dual Thrush glasspacks is still my favorite, even with thrush turbos instead they don't sound bad.
Old Dec 28, 2011 | 10:32 PM
91Bronc300's Avatar
91Bronc300
Another member here, Arctic Y Block, told me of a trick old inline 6 hot rodders used to do back in the day to get rid of the drone (he claimed they did it to pick up power, but that it also happened to get rid of the typical 6 cylinder drone).
They would create a dual exhaust setup that had 4 cylinders dump into one pipe and 2 cylinders dump into the other. One a 300 you would have cylinders 1,2,5,6 plumbed down to one collector and cylinders 3,4 plumbed to another collector. That would give you an exhaust pulse pattern of 2-1-2-1 much like a v8 pattern of 1-2-1-1-2-1. And different from the 1-1-1-1-1-1 of the dual exhaust you would get by plumbing the EFI manifolds all the way back as true duals. I would like to try this at some point but all my trucks and car are v8s. He said the tone of the exhaust was really something. I think this is the only way to change the actual notes that a straight six sings. Otherwise, you'll always have the drone in one shape or another.
Old Dec 29, 2011 | 08:29 AM
big-ugly's Avatar
big-ugly
This is some pretty interesting information. Thanks for sharing that. Now I am going to have to look into something similar.
michaelleiterman
Aug 6, 2014 09:23 AM
brian1985f150
Aug 1, 2011 08:18 PM
ford_man
Sep 25, 2007 09:53 PM
Michael Sizemore
64
Mar 28, 2007 12:11 PM
TallPaul
Aug 28, 2003 06:21 AM
