timing issue on 390 fe
Old Dec 27, 2011 | 09:22 AM
jmcnair40's Avatar
jmcnair40
Well, I'm almost embarrassed to post this question but......AS they say the only stupid question.......etc,,etc,, Anyway, Not sure where to start with timing on my 390 running an M.S.D. ready to run dist.(no brain box), R.V. Cam and I don't have the emmissions sticker anymore. Also can't remember if pinging is too much advance or not enough. Any thoughts on optimum setting? Please help with my brainfreeze THANX!
Old Dec 27, 2011 | 10:44 AM
MikePacey's Avatar
MikePacey
Pinging is to much advance. What I would do is set your timing to TDC the advance it by ear till is runs the smoothest. Then put a timing light on it and back it off a couple degrees.
Old Dec 27, 2011 | 05:07 PM
hotroddon's Avatar
hotroddon
I'm running a PerTronix all electronic distributor in my 75 FE (it's a 416") I am running 12° initial with the vacuum disconnected and about 36° total advance all in by 3500 rpm. I do run the vacuum, just disconnected during setting. Seems to run very good right there.
Old Dec 27, 2011 | 06:48 PM
Bullitt390's Avatar
Bullitt390
Certified Thread Hijacker
Set the initial timing to 8-12 degrees BTDC.
Josh
Old Dec 27, 2011 | 07:46 PM
mr. wackodog's Avatar
mr. wackodog
" if its a stock iron-headed fe u can run as much as 38 to 40 "at 3200rpm . if the ignition is a hot one u can increass the plug gap and run less total timing for more power and efficient. if it is heavy or high geared ofcours less timing.
Zazoos
Sep 6, 2016 10:56 PM
cespires3673
Jun 26, 2007 05:32 AM
Lionsfan
Aug 7, 2005 07:17 PM
good old ford
Sep 23, 2003 03:53 PM
kelsey
Sep 26, 2002 07:01 PM
