390 timing
Old Jun 25, 2007 | 01:35 PM
cespires3673's Avatar
cespires3673
Red face 390 timing
I'm having problems with the timing in my rebuilt 390 from CME out of SC tried everything but taking the timing cover off and checking which notch they set the timing chain on runs fine at an idle and normal driving but when you get into it it wants to spark rattle
Old Jun 25, 2007 | 02:45 PM
Freightrain's Avatar
Freightrain
What distributor do you have? stock? what's timing like, initial/total? Vacuum advance hooked up?
Old Jun 25, 2007 | 02:51 PM
cespires3673
stock distributor electronic , had to unhook advance for it to run desent
Old Jun 25, 2007 | 04:24 PM
Bear 45/70's Avatar
Bear 45/70
If unhooking the vacuum advance makes it run better usually mean initial timing is set to way high.
Old Jun 26, 2007 | 05:32 AM
cespires3673
set timing everywhere literally! it has a roller timing set i'm thinking that maybe the manufacturer set the timing chain on high instead of standard
riverguideguy
Oct 21, 2013 08:09 AM
riverguideguy
20
Mar 26, 2013 11:42 PM
71 Muddbugg
Oct 23, 2004 01:11 AM
BB
Dec 10, 2001 02:16 PM
390hiboy
Jul 26, 2001 10:32 PM
